Hard surface rod
/ Hard surface rod #1
FredH
Ruch , Oregon
N.H. TC-30
Curious question for for those of You with more experience , Which is All of You :)
Hardfacing Deposit Methods-Oxygen-Acetylene Process | Hero Protective Alloys
After reading above article , Am I understanding that instead of using a welder and melting the hard surface rod onto the object , like welding beads , That You would use a torch and " Melt " the rod and apply it that way ??
I was thinking about this the other day . Rather than using a welder , throw a bunch of hard surfacing rod into a pot and melt it then " Dip " the object into it . In that case , talking small objects .
Not sure , but may have found a large box , 5" high x 8" or so wide in a metal air tight box . Cardboard is really faded , so is hard to read . Rods are large in diameter, at least 1/4" , if not bigger . My Brother remembers Our Dad having hard surface rod , but does not remember what happen to it .
Not that I have anything that I would use that rod on , Was just trying to learn .
Fred H.
/ Hard surface rod #2
You need to bond the hard metal to the base metal. That requires melting the base metal too. But you don't need/want to get as much melting of the base metal as you would with regular welding rods. The idea is to dilute the hard surfacing metal as little as possible, to keep it's hard wearing properties.
Two layers are recommended, as the first one is mixed with the base metal but the second layer is mostly hardfacing.
/ Hard surface rod #3
CNC Dan has the method. I've even put a third coat on if a bit of build-up was needed.
I have found hardfacing rods require a lot of amps on the arc welder to sufficiently burn. 1/4" is going to take a fairly big welder and 200+ amp in my experience. But not knowing what you have will require experimentation to find out what works.
I have seen plow moldboards being hardfaced with an acetylene torch and it was brutally slow and very hot (the day was over 100° as well). That method seems best used for thin materials where minimal penetration is called for.
/ Hard surface rod #5
Wish I had a dollar for every pound of hard facing rod I've run. :D
/ Hard surface rod #6
In that case you'd only have a dollar which which you might be able to buy a cup of coffee in some places. Now if you have applied many pounds and you asked for a dollar for EACH pound you might have enough that will buy you a little more than a cup of coffee, even at Starbucks.
/ Hard surface rod #7
I worked for years drilling tiebacks, and solider pile. The augers need hard facing all the time.
Those auger pictures were drilling 200-feet into solid rock. For a bypass outfall around the Bonneville dam on the Columbia river.
/ Hard surface rod #8
So is there a difference between each pound and every pound?
/ Hard surface rod #10
Every is inclusive of all times, items whatever while each refers to individual occurrences, items etc. so if you have a dollar for every, that means exactly one dollar for all occurrences while if you get a dollar of each then you get a dollar for each occurrence or a whole heap a dollars.
/ Hard surface rod #11
So I often see hardfacing run in various hatching patterns...my understanding is that it helps trap rock or dirt on the sides of the implement so that the dirt/rock that is moving wears against the trapped material instead of the bucket or implement. So would there be any point in using beads of hatch patterns with a regular rod to do something similar, or would you not get the same effect as with the harder rod?
/ Hard surface rod #12
The hardfacing Ive seen is a large flux coated bronze rod containing small chips of tungsten. This is applied much like the brazing process. Ive seen it on the bottom of horse shoes - 3 one inch areas one at the front of the shoe and 2 at the opposing ends. This gives a horse traction when walking over pavement. Without it pavement is very slippery with just a smooth shoe.
/ Hard surface rod #13
Are you going to point out this grammar error every time or each time you see it? :)
/ Hard surface rod #14
Same effect, just that the build-up weld metal will wear faster because - wait for it - it's not as hard.
But for us here with our tractors it would be fine.
/ Hard surface rod
Thanks Every one . Although I could likely run the rod , Really have nothing to run / burn it onto ??? Not even sure what My Dad had it for . Looks like Maybe15 to 20 rods are missing out of 1 corner . Guess I could weigh it to see how much it weighs , Likely just take the storage box and put it box on the top shelf for another 20+ years .:D
Fred H.
/ Hard surface rod #16
So the instructions on the medicine bottle says, "Take a pill every three hours". What should I do?
When I looked up "every" in the dictionary, it says "1. each, individually and separately"
/ Hard surface rod #17
I think that's the definition that was giving me a headache.
/ Hard surface rod #18
Many times, esp. on the internet, folks have to prove how their a step above everyone else. It's just their method to make them feel important to others. Usually don't have a lick of common sense either!
If they were half as smart as they think they are, they'd be twice as smart as they really are.
/ Hard surface rod
The Last Sentence Says it All !!! :thumbsup:
I like that last sentence D2 , Going to borrow it . Thanks for Sharing . ;)
Fred H.
2012 Toyota Tundra SR5 Crew Cab Pickup Truck (A61568)
2012 Toyota Tundra...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2011 DOOSAN G25KW GENERATOR (A60736)
2011 DOOSAN G25KW...
2018 Ford F750 Mechanic Service Truck (A60352)
2018 Ford F750...
2016 Chevrolet Express 2500 Cargo Van (A61568)
2016 Chevrolet...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A60736)
2017 FORD F-150...
