Hard starting 555E
/ Hard starting 555E
I replaced the positive and negative cables. I replaced the ground cable that ran from the bolt on the starter to the frame of the machine to elininate and doubt wether or not there was a corrosion problem. All the ends that I cut back on the old cables had green corrosion in the for a long ways. I tested the battery and that tested out good. I put a charge on it tried it. It still seems like it starts out by turning slow but only for a fraction of a second and then its running. Maybe its the nature of the beast? Now the true test will be when I take the machine out for the night and try to start it on a cold morning. I can't do that until I fix the crack in the boom on the hoe end. So Stay Tuned!! Thank you everybody for your help with this and if you have any more ideas that I can try to make this better feel free to let me know.
/ Hard starting 555E #12
When l trying cranking my backhoe up the starter gets very hot quickly .what could be causing that? And it also won't start!
/ Hard starting 555E #13
what voltage is used on the 555E 12 or 24 volt ?
/ Hard starting 555E #15
Had a similiar problem on my 2000 model. Are you aware there are actually two batteries on the unit? The one you easily see when removing the grill cover is pretty easy. There is another battery underneath this one and you'll need to remove the top battery tray to access it.
The previous owner must not have know this as the bottom battery was original and totally drained.
Good luck.
/ Hard starting 555E #16
Good luck.
Might have two batteries, might not. two were optional. You are aware that this thread is almost 7 years old and the most recent post before yours is 11 months old?
/ Hard starting 555E #17
I have a 555e 1999 that just started jumping in and out of forward when it is setting in nuetral. Any one have any idea's of what is wrong?
Truck Storage Boxes (A59317)
Truck Storage...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
FIXED FIFTH WHEEL ATTACHMENT (A60736)
FIXED FIFTH WHEEL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
