Hard starting 555E
/ Hard starting 555E #1
crewman99
I have a 1999 New Holland 555E backhoe that starts very hard even with a fully charged new battery. The cable connections are all tight. :confused:
/ Hard starting 555E #2
I don't know about that engine in particular, but some of the basics are
Injection Pump timing
Injector pop off pressure and spray pattern
Valve clearance set correctly
Glow plugs working (or thermostart)
Air filter clean
Fuel filter clean
Fuel lines all tight from tank to injectors
Then you have to worry about compression as low compression will make a diesel hard to start. Many people will just resort to spraying ether and convert an engine that just needs rings, bearings and maybe valves into one that needs a total rebuild.
Hope it's something simple!
jb
/ Hard starting 555E #3
Does it turn over slowly or does it turn over normal but not want to run? We have a 555E at work that has had most of the starting system replaced over the years. Give a little more info.
It turns over very slow, if you get it to turn over fast it will start right up.
/ Hard starting 555E #5
Those problems can be a bugger to sort out,
You say all connections are tight, did you take them all apart and clean and reconnect them?
Get the battery tested, and get the starter in too a good rebuild shop to take it apart and eyeball it.
I just danced all over this with the Bobcat, and it is all simple stuff, just takes some time and effort.
I know on my backhoe, I have a "weak" cable on my positive side. But it is such a bugger to change I keep threatening to do it later :D
/ Hard starting 555E #6
I would start by tracing the ground cable out to make sure it is fastened to the tractor securely. I have had problems with that happening and most of the time it is the ground. Not on the battery but where it attaches to the frame if there is mud, rust, or just loose it causes the same slow start problem. I know on the Case 580k models the battery box can work loose from the frame and cause that, a little angle iron and a welder and she fires right up.
/ Hard starting 555E #7
That is good info above. Ours has ate several cable ends... even if they are tight and look ok you really need to take them off and inspect them. There is also a master disconnect switch on the right hand side that could cause similar problems.
/ Hard starting 555E #8
I'd replace the battery cables. Corrosion can get under the insulation and increase resistance. Also, run a ground cable from the battery ground to a bolt on the starter.
/ Hard starting 555E #9
my 555e was doing same thing,and the ground cable was coroded all the way,replaced it and starts with no problem now
/ Hard starting 555E #10
Are you sure the battery is good? Diesel engines need more amps then car engines and if your battery is marginal, it will have dificulty turning over the engine.
My 555E starts great in warm weather, but when it gets cold out, it cranks real slow. My problem is that my battery isn't up to the job. I made the mistake of letting my ex's cousin get me a "deal" on a new battery. He's been a diesel mechanic for over 30 years and is very knowledgable, but he doesn't apply that knowledge to what he does himself. He put a battery in there that doesn't have the amp rating required by the manual. Since winter is only two months here, I just deal with it and cuss him out every time I have to start it when it's cold out. LOL
Take out the battery and have it tested on a battery tester for cranking power. Voltage can be great, but when it's under load is what you need to know.
If that checks out good, pull the cables and clean them really good. Are they the factory installed cables? Sometimes people will cut corners and put in a cable that's smaller then original to save a buck. I had this on my dump truck. Once I replaced the thin cable with a larger one, all my problems disapeared.
Good luck,
Eddie
I replaced the positive and negative cables. I replaced the ground cable that ran from the bolt on the starter to the frame of the machine to elininate and doubt wether or not there was a corrosion problem. All the ends that I cut back on the old cables had green corrosion in the for a long ways. I tested the battery and that tested out good. I put a charge on it tried it. It still seems like it starts out by turning slow but only for a fraction of a second and then its running. Maybe its the nature of the beast? Now the true test will be when I take the machine out for the night and try to start it on a cold morning. I can't do that until I fix the crack in the boom on the hoe end. So Stay Tuned!! Thank you everybody for your help with this and if you have any more ideas that I can try to make this better feel free to let me know.
/ Hard starting 555E #12
When l trying cranking my backhoe up the starter gets very hot quickly .what could be causing that? And it also won't start!
/ Hard starting 555E #13
what voltage is used on the 555E 12 or 24 volt ?
/ Hard starting 555E #15
Had a similiar problem on my 2000 model. Are you aware there are actually two batteries on the unit? The one you easily see when removing the grill cover is pretty easy. There is another battery underneath this one and you'll need to remove the top battery tray to access it.
The previous owner must not have know this as the bottom battery was original and totally drained.
Good luck.
/ Hard starting 555E #16
Good luck.
Might have two batteries, might not. two were optional. You are aware that this thread is almost 7 years old and the most recent post before yours is 11 months old?
/ Hard starting 555E #17
I have a 555e 1999 that just started jumping in and out of forward when it is setting in nuetral. Any one have any idea's of what is wrong?
2000 Ford F-350 Pickup Truck (A66408)
2000 Ford F-350...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
72" JCT TILLER (A62613)
72" JCT TILLER...
JCB TELESCOPIC FORKLIFT (A65053)
JCB TELESCOPIC...
