Hard facing a bucket
/ Hard facing a bucket #1
Hookblock
WI
JD 4310
Hi, new to TBN have been reading for awhile, learned a lot ! I have a JD 4310 with a 410 loader I bought it used with about 400 hrs, very happy with it. I do have a driveway about 500 ft long and all gravel. The guy I bought the tractor from had a gravel driveway about 800 ft long. The bucket is starting to wear on the corners about 3/8". And with all the snow we are getting cleaning the driveway is becoming daily maintenance. I did do a search on hard facing, and I didn't find to much info. So my questions are:
1 is it worth it
2 any good advice for hard facing
3 is there a good pattern (ie; lines, x's, both, or other ideas)
4 is preheating necessary
5 better to replace the cutting edge
I stopped at the welding shop and they recommended Stoody 19 - 5/32'', but not much else when I asked the few questions above. The welder I have is a miller bobcat 225, and I have good welding basics. Thanks to all.
/ Hard facing a bucket #2
Hi Hookblock, and welcome. I'm fairly new to tractors, and learning a lot on the forum as well. I'm also considering hard facing my loader bucket ( I have hardfaced my shredder blades, and that has worked out pretty well ). Here's a link that might give you more information on how to lay out the beads on your bucket.
Hardfacing - Rockland Hardfacing helps protect bucket and attachments from abrasion, heat, and impact. Hardfacing on wear parts with carbide embedded hardfacing can extend part life by up to 5 times.
Let us know how it turns out.
/ Hard facing a bucket #3
We hardface our cutting edges at work on our pay-loaders... they seem to last longer than the road grader cutting edges.. etc.. No scientific proof to back that up.. just casual observation.. etc.. Our local welding supplier ordered us some rod that had good abrasion resistance characteristics.. dunno what# it was though..
soundguy
/ Hard facing a bucket #4
My poor (almost non existent) technique for clearing snow probably means I should be thinking about this.
It isn't the SNOW itself, more the sand and grit that the town puts on it - and of course the salt.
Tangent question; is salt more or less corrosive to hard faced edges ?
/ Hard facing a bucket #5
Howdi. Stoody 19 is a good choice as is 21, 31, 35 or wire such as 101,110. One thing to remember is if you have a half inch of material missing, You will need to build it up prior to hard facing. Hard facing materials should only be put on 2-3 layers. If you want a nice booklet on hard facing send me you address and I will send one to you.
MM ( Stoody Rep.)
/ Hard facing a bucket #6
Hookblock, I work for a large excavation company and they hardface almost all of the wear areas on dozers and excavators. The buckets and blades of all the machines get the hardfacing. It works and I am supprised at what a difference it makes. These machines are getting thousands of hours on them. I would say it is well worth the extra time and expense.
As far as your bucket you might want to check the floor and the back of the bucket to see if those areas are thinning. If the corners have wear then I would say that other areas are worn also.
Sincerely, Dirt
/ Hard facing a bucket #7
When I built the poor mans stump grinder, I took the time to hard surface all of the teeth with Stelite hard surfacing rods. There has been no wear on it, and I have been known to grind stumps with it. I would think if you can run a decent weld, it would be a good way to spend a day.
David from jax
/ Hard facing a bucket #8
I have been using mome made weld hardened edges for a long time now. At the very least, if it does wear down, you an build it up and re-grind it yourself as needed.
/ Hard facing a bucket #9
I had a friend that took his brand new bucket off his NH, turned it over and hardfaced the entire bottom of the cutting edge with his new welder. He turned it back over when done and his cutting edge, and his bucket, had a big bow in it. The heat warped it.
Someone with more experience than I should comment on the best way to avoid this.
/ Hard facing a bucket #10
This is the sort of thing that separates weldors from guys with welding equipment.
Owning a gun doesn't make you a marksman. There is no simple answer. It is a whole topic. Apparently the guy had not read nor heeded if he read) any books on welding. All I have seen mention the fact that welding heat causes metal to expand and that poor technique can warp pieces of metal and assemblies.
Asking what to do to prevent this is like asking a pilot to tell you how to fly and not crash, expecting a couple sentences to make you a pilot.
I'll mention a few things...
Taking it easy and letting the heat spread and dissipate is good. (Make haste slowly!) Alternately welding one side and then the other is useful some of the time. There is really no way to just tell someone how to not get heat distortiion while welding except some useless comment like just do it right and it won't warp.
I suggest reading on the topic in standard welding texts (Lincoln has a terrific welding book about 8x11x2 1/2 inches) then practicing to gain practical experience.
Amazon.com has oodles of welding books. I just looked and they have 48 books on welding. Reading and practicing will help as there is no simple couple sentences answer to make you a pilot, marksman, portrait painter or weldor. A class is even better. Finding a tutor who will work with you one on one is even better. Looking for a simple secret hint to transform a novice into a weldor is just NOT PROVIDENT.
Pat
/ Hard facing a bucket #11
Patrick brings up a good point!!
I have been welding roughly a year now at home and at work. I have welded up some things I wanted to be dead on. I like to weld things up like torquing head bolts, tack welds every 3 inches squaring things up, alternate sides and allow to cool some. I have noticed that if I get the dreaded "Ping" while cooling, something cooled rapidly. Get the tape measure out and check it. Using this method I have been managed to get things square within a couple of millimeters.
Granted I am not a professional welder, but a little thought and patience goes a long way.
Dan
/ Hard facing a bucket #12
Very true!
Pat
You pretty much summed it up in that though. "It is all about balance grasshopper" When you heat things, they expand. When you cool them they contract. When you lay down a weld bead, you are laying down molten metal over a certain ammount of area. This metal then solidifies and as it cools it shrinks. Take a new plastic garbage bag and lay it on a smooth surface such as a table top. Place your hands flat on the plastic sheet about an inch apart. This represents your weld bead. Now while pressing down, slide your hands together and see what happens to the sheet. This is your weld metal contracting. This effect is greatest at the surface. If you are welding on one surface of a sheet of steel, such as the bottom of a FEL bucket, you will shrink this surface. The opposite surface, without the weld remains the same. So one surface becomes shorter than the other. I just described a piece of pipe. The inner surface is shorter than the outer surface... With no force to resist it, the straight sheet will pull into an arc.
The easiest way to avoid this is to weld equally on both surfaces. Lay a bead on one side, flip it over and lay a bead in the same spot on the other side. This will aply the same shrinkage force to both surfaces and the sheet will remain relatively straight. For doing an edge, first weld one edge(one side of the sheet) then the other edge to apply balanced forces.
I finish weld much like I assemble. During assembly, I tack all over the place, measuring and aligning the assembly for true as I go along. When I weld, I weld all over the place, usually on opposite sides to apply counter shrinkage forces to keep the assembly square. Much like the described torque pattern used to keep an assembly square while tightning down it's fasteners.
/ Hard facing a bucket #13
Welding will cause the metal parts to pull towards the weld, so it will act as if the metal has shrunk. It expands initially, then shrinks as it cools. Was your friends bucket bowed up into the bucket (frowning bucket) or down (smiling bucket)?
The thing to do is go in small bits spread out. 4" here, 4" way there, 4" way over there, etc. He probably went in full beads, or as far as a stick would go, then did another bead next to that.
Thanks for all the input, I want to get set up better to pre heat the bucket. and I am waiting for some info from yomax4 (thank you). I hope to have something done by this weekend, or next week after christmas. AND will work on posting pictures
/ Hard facing a bucket #15
I mostly see hardface done in a cross hatch pattern. X
The little squares are about 1" to 2". I heard that there is some science behind it as you want to have the soils you work in to fill the spaces while you work. That acts like a buffer and keeps that area from wearing. The bucket then rides on the smaller area of hard face metal and only wears (slowly) there.
I would imagine that smaller squares for gravel and larger for soil, but that's not an expert opinion!
jb
Yomax4, I did receive the information you mailed. The cd was very informative. Based on the cd application recommendation, Stoody 19 or Stoody 31 would work. The 31 is more corrosion resistant, but I went with the 19. The material calculation figured that I needed 12 lbs of rods, which I thought that I could start with 10 lbs. Checked floor and back, it had consistent thinning.
The plan of attack is to preheat the bucket edge to about 200 degrees, using 5/32 rod at about 140 amps, reverse polarity, starting with cross hatch pattern in the main area of the cutting edge (alternating small welds from side to center to other side of bucket) and finishing with a straight bead on the main cutting edge. The bucket also has stiffener plates that run perpendicular to the cutting edge which I was also planning to cross hatch into the rotation. There's a small area along the outside of the bucket where I was going to run short parallel beads.
"it would be a good way to spend a day. David from jax"
I agree! :D
Two links that I found informative:
[URL="http://www.weldingweb.com/"]
/ Hard facing a bucket #17
It may be odd but sometimes just adding material is as important as adding hardfacing. I have actually used plain 1/8" 7018 rod to add a bead of material to the digging edge of each grouser on my bulldozer. The single bead was thin enough to offer a noticable traction advantage as well as preventing further wear on the grousers. That 7018 bead laster longer than I kept the dozer. It visibly smoothed/polished out with abrasion but was protecting the base metal for hunreds of hours. Easy as pie too. Almost my most pleasant welding experience ever.
Well today was the day I got something finished that I started awhile ago. I hit everything with a wire wheel.
The cutting edge I marked out at 3'' and the two straps that run with the bucket at 2''
Then the preheat. I got it to about 300 degrees, no picture then.
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2025 TEXAS PRIDE 14FT T/A DUMP TRAILER (A59914)
2025 TEXAS PRIDE...
2015 KENWORTH T880 (A67714)
2015 KENWORTH T880...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2022 INTERNATIONAL MV607 S/A 26FT NON CDL BOX TRUCK (A69167)
2022 INTERNATIONAL...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
