Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #13,141
Hey all, please stick to the topic and abide by the forum guidelines to keep this thread alive.
Have to keep staff like you busy. Keeps you off the street....lol Thankless job fir a person with an inflated ego.
   / Harbor Freight Tools that don't suck #13,142
Your 14" Lynxx takes a S52 chain.
3/8" low pro, .050 gauge, 52 links.
Question, is that the same replacement chain that fits the Portland corded polesaw? Looks to me like a 1/4" low kick back chain. Not that I need one because I'll sharpen the one on there many times.
   / Harbor Freight Tools that don't suck #13,143
Another good tool for the money.
Finally installed the lift on my shop and needed a good way to change fluids, used something similar at my family's shop. Seems well built and you can use the 20% coupon on it.
I did add this Lisle catch pan View attachment 646054 because the drain area is a little small for my liking, same setup I had at the family shop.
I have the baby brother to it, the 5 gallon one. I ended up replacing the funnel on the top with a metal one made by Lincoln when the front bumper caught the edge of the plastic and snapped it. Over the years it's built up a layer of sludge in the bottom and I have to remove the drain cap (no air power extraction) and prop it up to let the fluid drain out over a couple of days. I also had to paint the bottom as the red paint was flaking off almost immediately. Other than that it works just fine.
   / Harbor Freight Tools that don't suck #13,145
Back to tools from HF:
I bought the Lynxx battery powered pole saw based on all y'alls recommendation and have been quite pleased with it. The battery lasts longer than I do and it's done quite well cutting up brush and full size oak trees. I have/had a 30' x 30' oak tree that needed to come down because it was hollow and I could control where it landed if I had it cut down, and since the logger was already there with their tree shear, it was down in moments. The pole saw did a marvelous job of cutting the branches up into firewood. With the branches being upwards of 8" & 9" in diameter. The trunk is ~24" so I've switched to a gas saw for that. But, do you know what the replacement chain is for the Lynxx pole saw? I thought there was a number stamped on one of the links on an oregon chain, but I don't see it. I do see the "oregon" on each of the cutters. There is a "oregon 91" on the bar which would indicate a 3/8" low profile chain but a 14" bar. But what is the ordering number for a replacement chain? My Poulan chain saw is an "S56"
I kept the Oregon bag, the chain came in, for both Lynxx pole saw and chain saw. I'll get a picture of the pole saw one .. in the morning and post it for you.
BYW .. the pole saw bar is a 10" not 14". The Lynxx chain saw is 14".
   / Harbor Freight Tools that don't suck #13,146
No it wouldn't be the same chain but I don't know what it would take.
   / Harbor Freight Tools that don't suck #13,147
Come on guys, we're talking about tools not about one another.
BTW, how are you doing? I read that you said you were ill. You ok?
Musta been some otherbody. I'm fine, family too. Thanks for asking.
I recently mentioned that a wedding reception site cancelled on us for this coming weekend. Their call, anticipating the total Bay Area shutdown. So what we prepaid will be refunded. If they're still solvent.
Oh and I posted about getting lunch near Travis AFB just hours before the first case appeared in the community outside of that quarantine site (Princess Cruise passengers).
I'm not aware of any cases I could have been near. But with this doubling nearly daily, I think for all of us its just a matter of time. Hopefully, mostly light cases.
Do we know of anyone on TBN yet?
   / Harbor Freight Tools that don't suck #13,148
None that I’m aware of ...
   / Harbor Freight Tools that don't suck #13,149
So long as my local HF don't close, all is well with me... Need a new 1/2" cordless drill (Bauer), found the smoke in my DeWalt the other day. Interestingly, smelled like rice paper.:D
   / Harbor Freight Tools that don't suck #13,150
Would be unlikely to ascertain unless you tracked by comment. If someone is a regular poster and vanished, you could ascertain that they became a victim.
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
Giyi 43" Disc Mulcher (A57149)
Giyi 43" Disc...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58216)
1982 SHOP BUILT...
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
