Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #8,801
I thought I posted a thread specific to HF blast cabinet mod but I can't seem to find it. Maybe I didn't and probably should start a thread if I didn't...
I have heavily modded my cabinet but one of the items that didn't get an upgrade until now were the gloves. They do suck! They split pretty early in the use cycle and I have been using duct tape with not great luck to hold them together. Replaced the originals with new ones from the Tacoma Company. Highly recommend them if you want to turn your HF cabinet into a first class machine.
View attachment 545924 View attachment 545927
As I said, lots of mods but I learned pretty quick that it is nice to have quick access to the whole insides of the cabinet so I got so I modified a socket... View attachment 545926 View attachment 545925
New gloves installed and a peek at some other sweet upgrades from Tacoma Company...
View attachment 545928 View attachment 545929
Thought I had another spare pane of glass. But I guess not. :smiley_aafz: So another trip to HD before I button this up.
To extend the life of the glass try black window bug screen spaced about 1/4" from the glass. The media will bounce off of the screen but you still have a decent view of your work and it will save the glass.
/ Harbor Freight Tools that don't suck #8,802
Thanks for the tip! I go through single weight glass far more than I had hoped.
/ Harbor Freight Tools that don't suck #8,803
the screen tip IS a good one.. I'll hafta give it a try..
I don't know what a replacement glass costs from HF, but my HF is about 50 miles from me..{100 r/t}
.. & I just went to the hardware store w/ my old glass & they used it as a template to cut me a new piece for a few dollars..{cheap}
Lasts the same amount of time.. IMO
/ Harbor Freight Tools that don't suck #8,805
I neither have a sand blast cabinet, nor need one, but I wondered if [given its increased hardness] tempered glass would last longer than the lexan or window glass, plus I guess I'm just curious by nature- anyway, this thread:Protective film for your sandblast cabinet. What do you use? - The Garage Journal Board has a lot of work-arounds for prolonging glass life-
One of them that stood out to me was using a cell-screen or tablet-sized screen protector of one of the gorilla-glass knock-offs to get a more durable view port in the bigger window.
Also here's another supply place for SB components- including tempered glass [? what sizes you need tho...]
Sandblast Cabinet Parts & Supplies for Abrasive Blasting Cabinets - TP Tools & Equipment
and
Sandblasting Cabinet Window Protector - All Clear Products
YMMV.
/ Harbor Freight Tools that don't suck #8,806
Or you could sell the used glass on Craigslist for a premium...
"Frosted glass pane. Only one left to sell."
/ Harbor Freight Tools that don't suck #8,807
. All clouds have a silver Lining!
/ Harbor Freight Tools that don't suck #8,808
I personally use the film on my glass and it works very well. I have a Skat Blast cabinet and been using the film for years with great success. The other thing is add a filter system - it makes a huge difference in visibility and filters the dust out of the cabinet.
/ Harbor Freight Tools that don't suck #8,809
That's another one of the things I gleaned while looking into the question [dust avoidance], from here:
Clearwater Glass Studio
/ Harbor Freight Tools that don't suck #8,810
I do have a first class filtering system. I suppose I should get off my arse and post a thread on my HF blast cabinet mods. Wait... that means more arse time! :confused2:
There are a few youtube vids on mods... I went to school on most all of them before I invested.
/ Harbor Freight Tools that don't suck #8,811
HF sells the vac/filter canister to hook up to the cabinet for 143.00..
I also "heard" that MOST people use a shop vac to suck the dust.. BUT..
1 guy said if you run a FAN instead.. it works better..?? Just something small like a computer fan..
I guess it forces the dust out the hole..??
/ Harbor Freight Tools that don't suck #8,812
I did see one suggestion to use a piece of brake line to make a diverter using air parasited from the supply hose to keep a small but constant steady stream of air blowing across the inside of the "glass" [kind of like the air wash my wood stove uses to keep the glass on the front cleaner...]
/ Harbor Freight Tools that don't suck #8,813
I picked up 2 snatch blocks Snatch Block and 2 3/8"x65' cables 3/8 in. x 65 ft. Replacement Winch Cable with Hook last week. The cables are replacements intended for winches, but I wanted to try them for pulling logs with my tractors. I added cable eyes and double clamps to the open ends of each cable and added a clevis hook to one of those eyes. I really had doubts this would work to pull a 20" ash across a creek and snake it back and forth through the woods to a point I could pull it out with a short chain. Using the blocks to double the cable gave me the slow power to pull the tree though the creek, deep mud, and onto higher ground. Then I cut the tree into 15' lengths and pulled with the single cables and multiple chains (over 200' total distance), snaking the logs through the woods. Overall I was really impressed with how the blocks worked, and the cables are still in great shape. I'm looking forward to having these cables and blocks to help drag out more trees that are in wet inaccessible areas of the woods.
/ Harbor Freight Tools that don't suck #8,815
25% this Saturday and Sunday. 20% friday. Coupons probably on line. I got an email and they were handing them out in store several weeks ago
/ Harbor Freight Tools that don't suck #8,816
1522505830904.jpgusing my harbor freight cart to unload the tool box I bought there. Is that how you know you have a problem?
/ Harbor Freight Tools that don't suck #8,819
Series 2 vs Blue-point
/ Harbor Freight Tools that don't suck #8,820
The US General Series 2 looks very nice. I may have to pick one up soon.
Harbor Freight is really raising the bar.
2014 Ram 1500 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 Crew...
iDrive TDS-2010H...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2011 Ram 1500 Pickup Truck (A59230)
2011 Ram 1500...
2014 Jacobsen Groom Master II Bunker Rake (A59228)
2014 Jacobsen...
iDrive TDS-2010H...
