Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,151
Hi LD,
Thanks, I was wondering if that was how you were doing it- I'll have to get one of those blades.
Thanks also for the reminder about safe practices- I'm almost always scrupulous about those things- I get a fair amount of practice pulling metal fragments out of corneas at work, AND suturing the digits that got too close to the spinning metal, so a lot of the safety stuff comes naturally any more.
I thought about going along with the recall for the Craftsman saw, but after looking into it, I found out that they don't just want the motor, they require return of the whole carriage it uses to attach to the arm as well [which is good sense on their part as it completely disables the saw], and that would be a shame as I'm happy with the whole thing otherwise- and I'm extremely cautious with any chance of blade contact no matter how I use it.
Thanks again,
PA
We had the model with DRO that worked well and years ago recall had option of new table and guards so completed.
But arm made of rolled steel and chappy design so loose fit.
Picked up an older model all cast iron but same motor so transfered parts to new to us unit and sent in DRO model and got our 100 bucks...The older one substantial better unit.
Still have the frame to make something out of...
   / Harbor Freight Tools that don't suck #8,152
I noticed the 2-ton aluminum racing floor jack is back on sale for $120. I've only used mine once, but I thought it was great.
I'm kind of wishing I'd purchased one of the new Predator 3500W inverter generators back when they were $649.
   / Harbor Freight Tools that don't suck #8,153
   / Harbor Freight Tools that don't suck #8,154
On sale right now for $699
   / Harbor Freight Tools that don't suck #8,155
Even better -- $659. I should just do it!
   / Harbor Freight Tools that don't suck #8,157
This Harbor Freight 11/16 end wrench definitely does not suck. I needed to get the chuck off my old Milwaukee drill so I could install the Right Angle attachment. Have not had to do that for decades so the chuck was on pretty solid. The spindle nut is 11/16 but the opening is too narrow for a standard end wrench. In years past I would grind down a Craftsman wrench and that would do the job, but I did not want to grind one of my good remaining Craftsman tools. So went to HF and got the set for $9. Ground the wrench down to about 1/2 its thickness using a belt sander. The sparks were bright and lively so I figured the steel had to be pretty good. When it was thin enough I put it on the spindle nut and hammered away on the chuck tool. The chuck finally came off but not easily. So this HF wrench has been given a real torture test and performed perfect. I also used it to assemble the Right Angle attachment but that was a piece of cake.
   / Harbor Freight Tools that don't suck #8,160
I KNOW this is a HF thread BUT>
I just ordered a 10k watt, electric start, DUEL FUEL gen from amazon for 499.99 w/ FREE shipping.. Duro-Max gen.
The sale is off now tho.. they're 1499.99 now.
Find the site & save it to your "favorites" & check often.. the cheapest I've seen THAT gen was 599.99 about 6 months ago..
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56859)
Pace American...
New/Unused 7ft Work Bench (A57454)
New/Unused 7ft...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
LOT: (36) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #2 Grease (A59076)
LOT: (36) 14 Oz...
REDDICK 300 GALLON FRONT MOUNTY POLY TANK (A52708)
REDDICK 300 GALLON...
2015 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
