Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,111
   / Harbor Freight Tools that don't suck #8,112
I prefer the stuffed-olive slender glass jars. Even if there are dis-similar objects in one jar I can find that odd item - for example a sewing thimble - faster than popping open dozens of drawers.
I'd rather go with plastic jars or metal cans than glass...a lot less hazardous when ol' butterfingers drops one. :(
Harbor freight 12 ton stands for fixing flats. They are a good height.View attachment 529951
Don't worry, it's only flat on the bottom. :D
   / Harbor Freight Tools that don't suck #8,113
I bought two of the 30 bin racks when they were on sale for $15, but have yet to mount them. Gotta clear up some wall space. They'll be used mostly for all those 1lb boxes of trim screws, deck screws, Tapcons, etc.. All my screws/bolts/nuts/washers go in clear plastic jars (mayo, pickle). One jar for each type (machine, countersunk wood, pan head, etc.).
Then, a couple of THESE -
are indispensable for dumping out the jars to find exactly what's needed.
   / Harbor Freight Tools that don't suck #8,115
Yes! Those are indispensable. Can hardly dispense without them! :)
Really, one of the handiest products that HF sells.
What do you call them? They do look handy.
   / Harbor Freight Tools that don't suck #8,116
3 Bin Wall Mount Parts Rack
Anyone use the above? I am just a homeowner, not a commercial repair guy. Building up the usual assortment of nuts, bolts, screws and whatsits from projects. Like to keep the left overs organized so when the next project comes along I don't have to run to the hardware store.
So I do not need anything too beefy, it will get some occasional use.
I've two and use them primarily for nuts, bolts, washers etc.
Checking hfqpdb they often have a coupon for $14 http://www.hfqpdb.com/coupons/329_ITEM_30_BIN_WALL_MOUNT_PARTS_RACK_1506754480.3502.png
   / Harbor Freight Tools that don't suck #8,117
And note that the 1"x 30" BELT SANDER has a coupon for $40. This is an excellent sander for sharpening knives.
   / Harbor Freight Tools that don't suck #8,118
HF Funnel tray. $2.99
530011d1511909946t-harbor-freight-tools-dont-suck-image_17574-jpg
Highly recommended! These are ideal to dump out a random mix, say nuts/bolts/washers of one size - to find the one lockwasher you know was in there, and then pour everything back into the container.
   / Harbor Freight Tools that don't suck #8,119
Can't believe I've never seen them either. How handy would they "had been".
   / Harbor Freight Tools that don't suck #8,120
i use an old square steel cake pan with one corner cut off.
Bruce
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2000 TL (A50322)
2000 TL (A50322)
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
