Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #14,041
Like your hose reel, I may do the same with my hoses. Is that an HF reel per chance?
There are hose reels and then their are hose reels. For O/A service they are very specific as to the rotating seals that get considerable wear and are specifically made for the service. Some even have auto retrieve. Used a lot on field welding trucks. Same thing with quick connect hose fittings. Be careful, spend the money and get stuff made for the O/A service. Routinely check the devices for leaks. As HF upgrades their line of tools/equipment the quality has improved exponentially but the price has not increased at the same rate so still a bargain. Seems they are moving away from communist china to other Asian country manufacturers. We still need to bring more things back from off-shore.
Ron
/ Harbor Freight Tools that don't suck #14,042
On the subject of acetylene withdrawal rates: Using large welding/brazing/heating nozzles of any configuration is dangerous with the smaller acetylene cylinders. Any cylinder smaller than 100 CF is vulnerable to releasing acetone from the internal absorbent material. The regulators made for the smaller size O/A sets like the Victor 100 and J series will not pass enough volume to exceed the cylinder dangerous safe withdrawal rate. Using larger regulators compounds the safety margin. Standard recommended acetylene torch side pressure of 5 psi will also keep within safe boundaries. For large heating projects it is safer to use propane of natural gas instead of acetylene. If you do though remember to use only type T hose. Those gases will breakdown the regular type R hoses. Yes, type T costs more per FT.
Ron
/ Harbor Freight Tools that don't suck #14,043
My acetylene tank is probably on the too small side. It is a hobby tank, probably 3 foot tall and 8 or so inches in diameter. So what exactly happens if you draw it down too fast?
/ Harbor Freight Tools that don't suck #14,044
Keep your acetylene delivery pressure to torch no higher than 5 PSI and you should be OK except for large tips (#6) and rosebud heating tips. If yo use a tip larger than a #2 you are probably larger than you need to be anyway. I used to weld EX heavy pipe with a #2 tip. You are safe with a #4.
Ron
/ Harbor Freight Tools that don't suck #14,045
Acetylene in the tank is dissolved in acetone for safety. 15 PSI is the safety limit for pure acetylene. Can only boil out so fast before you start getting acetone, purple, in your flame. Rule of thumb is 1/7 per hour. So an 8" diameter by 36" long cylinder might be 12 cu ft, you should not use more than 1.7 cu ft/hour.
/ Harbor Freight Tools that don't suck #14,046
This is all good to know and is all news to me. I have never had any formal training on using my torch even though I have been using it on infrequent occasions for 30+ years. Mostly for brazing, light welding and cutting. I empty out a tank maybe every two years or maybe longer. I use my arc welder a lot more. Please be patience with my ignorance. What is the worst that might happen if I develop one of these purple acetone flames? Also what might happen if I exceed 15 psi?
/ Harbor Freight Tools that don't suck #14,047
I Keep forgetting! I bought a $20 DA, dual action buffer. It's great! My $6 HF screw gun gets more use than any other tool but it might be on its last legs, starting to make funny sounds! And my $20 chicago angle grinder just keeps on keeping on.
/ Harbor Freight Tools that don't suck #14,048
I recently had a local mechanic rebuild the engine on my wifes gas powered utility cart and he uses mostly H.F. tools. When we talked about it he said he couldn't afford to have Snap-On as a dependent along with his 4 kids. The guy was surprisingly good and reasonably priced, I'll use him again.
When I asked him how well the tools hold up for him he said "fine and if there's a problem, they take care of it.'
For a small engine mechanic, I don't see that it makes much sense to spend 3x the price for Snap-On, Mac, etc. tools when decent quality box store tools will stand up just fine, especially if he doesn't need to finance the purchase. Keep in mind though that HF has only been a practical option for most of us only for the last 5-10 years when they expanded. I don't know how widespread their stores were on the west coast in the past, but here in the northeast they've only had much of a presence for the last decade or so.
I think the jury is still out on that, or at least with power tools. Yeah the newer "brands" don't feel quite as cheap as the old Chicago Electric crap, but time will tell on how they stand up. Agree their hand tools seem to be as good as anyone else's. Can't comment on air tools since I have no need for them.
As far as bringing manufacturing back to the U.S., sorry but that ship sailed a long time ago. Our workforce has long since priced themselves out of that market, at least for reasonably priced consumer goods.
/ Harbor Freight Tools that don't suck #14,049
There have been a few good videos on teardowns of some of the newer battery tools and they are actually pretty decent and comparable to a lot of the bigger name brand tools out there. The Earthquake line is especially impressive.
As for air tools, they still have cheaper lines but their newer stuff is pretty good. I recently bought some if the Chief tools, a 3in cutoff and an extended die grinder, made in Taiwan not China, and seem to be well built (time will tell).
I really like the Baxter line, have one of their band filer and it works well, even comes with ceramic bands that are made in Germany!
/ Harbor Freight Tools that don't suck #14,050
Acetylene gets unstable above 15psi. A.k.a kaboom.
Acetone is a solvent & can melt plastics or rubbers, which make up your hoses & regulators. Also, if you need X amount of Acetylene in the tank to properly dissolve Y amount of Acetylene into things into, it works fine. If you have less than X, you can't fill it as full, or if you try to, you go over 15psi.
/ Harbor Freight Tools that don't suck #14,051
Cougs (and all) - if you're serious about finding out more, you should go back and read ALL the info in the link I posted
Fuel your safety knowledge
It will answer pretty much every question you may have.
Also, everyone - according to that report, the NEW MAXIMUM recommended withdrawal is EVEN LESS THAN BEFORE, they now say ONLY 1/10 OF THE CYLINDER VOLUME PER HOUR -
For those who REALLY don't wanna read, the two MAIN REASONS for knowing about this are FIRES and EXPLOSIONS ... Steve
/ Harbor Freight Tools that don't suck #14,053
You can always buy the Milwaukee 'Fuel' stuff and pay a premium price for offshore made anyway. Not in my toolbox.
My Bauer 20 volt stuff is alive and well and never an issue and I use them constantly.
/ Harbor Freight Tools that don't suck #14,055
Cougs, you're entirely welcome; I figure that if I was given a "raincheck" on death by at least 55 years (so far) the least I can do is pass it on when given the chance...
"Why ganged tanks are necessary. Real simple. OOOps, wrong term, ganged bottles, not tanks"
5030, after all the (pre-internet) study I did, I knew I didn't wanna mess with ganged bottles so I did the math; the largest Acetylene bottle and the next to smallest rosebud (at the time) satisfied the withdrawal rate, and since I'm not into huge earthmovers it's been fine for me since I bought my tanks in the '70's... Steve
/ Harbor Freight Tools that don't suck #14,056
Not sure about the earthmover stuff. What I stated originally was I know a guy who arches steel flatbed trailers and uses a big rosebud to heat the upper and lower flanges so they contract and curve. I don't get into that stuff at all. Just watch and he uses ganged bottles of oxygen and acetylene.
Not my thing at all.
/ Harbor Freight Tools that don't suck #14,057
Yeah, that'd be another place where you'd need a LOT of heat for sure; I've done a few similar things but on a MUCH smaller scale (and with mixed results) - the "earthmover" comment just meant jobs big enough to NEED all the hassle of ganged bottles, bigger hoses, bigger torches, etc - that hasn't been me, biggest thing I own is a roughly 30,000# manlift and a 12k backhoe... Steve
/ Harbor Freight Tools that don't suck #14,058
Have we talked about the 'goes through' socket sets yet? I got the old style Pittsburgh, but they have a newer version now. Thinking about getting another set some day as they come in mighty handy for longer bolts or threaded rod.
/ Harbor Freight Tools that don't suck #14,059
Quote---"As far as bringing manufacturing back to the U.S., sorry but that ship sailed a long time ago. Our workforce has long since priced themselves out of that market, at least for reasonably priced consumer goods."
Problem there is gov'ts subsidized under aid projects support for those 3'rd world countries.
Most often with high performance robotic assembly equipment that supported US firms.
Well that has come back to bite us.
Those 3'rd world's use it but with $2-3-4 hr/hr workers and that simply can't compete with our high priced unionized workers.
We brought it upon ourselves!
/ Harbor Freight Tools that don't suck #14,060
It isn't just the labor cost;
it is also the energy cost and the excess burdensome government regulations.
OSHA and IMSHA and the EPA have hamstrung manufacturing in the US.
Some safety and regulations are needed but we have gone so far overboard it is ridiculous.
UNUSED KJ K4020-40' X 20' STEEL CARPORT SHED (A60432)
UNUSED KJ...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A60430)
UNUSED SET OF...
2018 Dodge 5500 Bucket Truck 4WD (A61306)
2018 Dodge 5500...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
