Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #12,122
Not me so much either but needed the flex handle.
Do a longer term test for us. I'm curious as to how the grip holds up. Already know it will lose it's pretty color with one greasy use.... What I'm curious about is, will it crack and come off. Chinesum rubber isn't noted for longevity... I do like the double gear ratchet design though. Much better than the pawl design.
The standard (no grip) handles sure look like another well known tool truck brand....:D
/ Harbor Freight Tools that don't suck #12,123
Will do. The fine ratcheting surprised me playing with the demo tool at the store. I’ve blown out old craftsman ratchets so I’m worried about strength but with a small 1/4in drive, I often need finer gears to work in tight spaces. Excited to see how this performs.
/ Harbor Freight Tools that don't suck #12,124
5030,
Wasn't it you who was going to get the Bauer impact driver? 2V Hypermax Lithium 1/4 in. Hex Compact Impact Driver, Kit
Did you buy it? If so, have you tried it on Phillips screws and how well did it work? Every drill I ever used spun the slots out and ruined the bits in short order. I've heard that impact drivers do a better job.
Thanks,
Stuck
/ Harbor Freight Tools that don't suck #12,125
I got a Ryobi 1/4" impact that seems to work well on Phillips, Square and Torx. Put some 3" drywall screws through 2xs into 4x4s with no effort. I've taken a few out and put them back in with no head damage.
/ Harbor Freight Tools that don't suck #12,126
What can you say about a bucket? Well, the people who reviewed it found something to say. I read a couple and couldn't tell whether they were serious or tongue-in-check.
Well when I did renovations and building I always ordered a couple of drywall mud in buckets as part of an order.
Often the price was even the same as the boxed mud so I still have a supply.
One usage is to store my tractor chains.
Now as to tools------
many years ago a client went to China to visit and buy power tools for resale.
He described the production line as being stopped every so often to change the labels.
He actually saw Snap On change over to Harbor Freight, Sears etc etc.
Notice as to how today's tool castings simply have a indentation to where they stick the brand label.
On high ticket tools the insert is 'quality' while on the 'el cheepo' it might just be a paper label.
/ Harbor Freight Tools that don't suck #12,127
I love my buckets!! use em for tons of stuff! Nuts/bolts, chains, fencing supplies, just whatever. Even works well in a boat for keeping fish live. I like the ones with lids as it keeps everything inside clean. Yes, I have lots of storage buckets around. Not sure the HF ones have lids. Was in construction for most of my life, I have empty paint buckets, sheetrock mud buckets, hydraulic buckets from around the farm. If you go to lowes, you can get a free bucket with 4.5 gal of dry wall mud for $14.99 .
I even bought some food grade buckets I use for emergency food storage for when the zombies (or democrats) take over !!:D
/ Harbor Freight Tools that don't suck #12,128
Comparing an impact driver to a drill isnt quite as impressive as comparing a drill to a manual screwdriver, but still impressive. An impact will drive screws a lot better than a drill under challenging conditions while not trying to break your wrists. I'm not sure I've tried one with a slot drive, but all the others work well.
On a similar note, I've abandoned Philips screws for Torex. Phillips were designed to cam (slip) out under high loads back in the day before torque limiting drivers. Robertson (square) are better & Torex are WAY better than Philips or slot screws.
/ Harbor Freight Tools that don't suck #12,129
Torx I think, not Torex.. that's a semiconductor..
/ Harbor Freight Tools that don't suck #12,130
On a similar note, I've abandoned Philips screws for Torex. .
One thing that most do not realize when comparing Torx to Phillips is that Torx tend to drive more easily because 99% have a drill tip...most Phillips do not.
/ Harbor Freight Tools that don't suck #12,131
True. But I have boxes of identical screws except for the drive type up in the shop at the moment. The torx ones often have that notch on the tip for a bit of self-drilling, but some Philip's have it as well & some torx dont. It does help, but I'm not sure if it's as much as the coupler not trying to cam out.
/ Harbor Freight Tools that don't suck #12,132
I love my buckets!! use em for tons of stuff! Nuts/bolts, chains, fencing supplies, just whatever. Even works well in a boat for keeping fish live. I like the ones with lids as it keeps everything inside clean. Yes, I have lots of storage buckets around.[snip]
Yup, and those of us who have had indoor cats probably have a good supply of "kitty litter" buckets. Complete with lids. :laughing:
/ Harbor Freight Tools that don't suck #12,134
I have a standing order with all the neighbors to bring me their empty kitty litter buckets. Typically 3 or 3.5 gallon size. Rectangular is best for apple harvest. Hang it from a branch or an upper stair on the ladder using an 'S' hook. The apples are only handled once, into the bucket, then later that filled bucket is given to family, friends, neighbors.
One thing I've found - the oval Fresh Step buckets are intentionally biodegradable. After a few years a chunk will break off if you pick it up by the edge.
/ Harbor Freight Tools that don't suck #12,135
I have cats , but no litter box!! I train my cats to use the cat flap door and go outside like nice kitties!!
Don't like the smell from a litter box, even well taken care of and clean litter boxes still smell.
/ Harbor Freight Tools that don't suck #12,136
Well at least the free bucket I got wasnt made in China.
It was made in the Peoples Republic of California. 😁
/ Harbor Freight Tools that don't suck #12,137
It was made in the Peoples Republic of California. ��
Soon to be known as "The Peoples Republic of Mexifornia"
/ Harbor Freight Tools that don't suck #12,140
I wish hey still sold it in those buckets.
They don't? Then I need to request HF free buckets from the city neighbors, in exchange for the apples I pick for them.
Kitty Litter in biodegradable bags instead of plastic buckets makes more sense when you think about it.
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2019 Toro Workman GTX Electric Utility Cart (A59228)
2019 Toro Workman...
2017 Toyota Hybrid Camry Sedan (A59231)
2017 Toyota Hybrid...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
