Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #10,141
You did good. That looks like a better tool than HF's blue paddle-switch 6 amp version.
I like the NT grinder because it has an off / on switch. I'd think the paddle switch would be unwieldy, in the cut off adapter, unless you could lock it on?
/ Harbor Freight Tools that don't suck #10,142
I have the HF cheap and intermediate grinders in addition to the paddle switch one. When I tried HF's grinder cutoff mount I installed the $10 HF grinder in it, because that grinder wasn't as useful as the intermediate one that was my primary grinder at the time. It didn't take much loading, weight, on the grinder to make the disc wander off the layout line without bogging down the grinder. I quit using the flimsy HF mount at that point. It seemed dangerous.
I think HF's $10 angle grinder should be sufficient to put in the new NT mount as a cutoff saw. It has a slide on/of switch. This use doesn't work the grinder very hard.
/ Harbor Freight Tools that don't suck #10,143
I have a HF grinder with a paddle switch and don't like it.
/ Harbor Freight Tools that don't suck #10,144
So, Harbor freight has 3 options for wrench sorting. One is the Wrench-It-To-Me, it's one of the few third party products that is resold by HF.
Next is a pair of similar designed wedge shaped racks, one being steel for $6.99 and one being a soft plastic almost rubbery material for $5.99.
The first mentioned is a large rectangle with various large wrench, small wrench and hex key Allen wrench sorting areas. My problem with those one is that it just takes to much space as it is and needs to be dissected to remove the hex key areas and make each segment modular. I'll do that this weekend with my Dremel.
76 Pc Wrench Organizer
Then you have the steel and plastic, both share a common trait that for me is no good. The issue for me is that these are made to positively engage the wrenches and provide a carry handle. I do not want to have the space if the handle taken and I do not want to push and rotate the wrenches in and out of the grippers every time I need to interact with this. So I bought 4, cut the handles off by scoring with a utility knife and bending/cracking the handle off. Then I took diagonal cutters and snapped the latching hooks off to make these work as I desired. Now we are talking! Attached is a photo of a pre cut and post cut plastic one. I'll segment out the Wrench-It-To-Me to create 4 more sets of similar organizers, and I'll move the hex key part to the hex key drawer. Win win.
The plastic one I got for $5.99 minus the 20% coupon and with tax for $5.08.
16 Slot Wrench Rack
The steel version would be more difficult to modify to this configuration, so even though I like metal over plastic... In this instance the plastic is clearly better to fit my desired use. 20181106_191550.jpeg20181106_191606.jpeg20181106_192955.jpeg20181106_193008.jpeg
/ Harbor Freight Tools that don't suck #10,145
I have one and while it works OK for my use, I'm not wild about the paddle switch. Mine CAN be locked on though, so you could plug it in to a switched outlet box and turn it on/off that way while mounted in the adapter.
/ Harbor Freight Tools that don't suck #10,146
[snip]
Attached is a photo of a pre cut and post cut plastic one. I'll segment out the Wrench-It-To-Me to create 4 more sets of similar organizers, and I'll move the hex key part to the hex key drawer. Win win.View attachment 577798View attachment 577799View attachment 577800View attachment 577801
Well done, RockCrawler. But hopefully there's a solution for those crow's foot wrenches in the bottom left corner of that last drawer. They aren't staying lined up nicely like the rest. ;)
/ Harbor Freight Tools that don't suck #10,147
It's a work in progress. I'm working 6am to 6:30 pm for another week and a half, Sundays off. So I get home around 7:30 and spend an hour in the garage playing with this organization while drinking a couple Coronas... I go to sleep around 9 and wake up at 4am.
I want to trim the unused length from those wrench racks as well. At the same time, I'm trying to split off a set of everything into the HF 4 drawer roller cart for pulling outside to the tractor. The idea is to have a rolling basic set that prevents me from needing to walk back and forth to the main box when I have something going on outside.
I also have another HF 4 drawer roller in my lower set of bays that I'm doing the same in. I'm actually thinking that I might get that 301 piece Pittsburgh set from HF for the lower garages. That's a pretty decent basic kit to minimize humping upstairs for every tool need.
There is only so much time and only so much money that can apply at one time, do I'm calling this a winter project with respect to both time and money.
/ Harbor Freight Tools that don't suck #10,148
I have it, too, and actually like it. It was the paddle switch that sold me on it. I've had no issues with mine.
/ Harbor Freight Tools that don't suck #10,149
For me, probably more frustrating than not owing the right tool for a project is owning the right tool but not having it with me when I need it!
/ Harbor Freight Tools that don't suck #10,150
16 Slot Wrench Rack
The steel version would be more difficult to modify to this configuration, so even though I like metal over plastic... In this instance the plastic is clearly better to fit my desired use.View attachment 577798View attachment 577799View attachment 577800View attachment 577801
They all stink. To me its easier to just lay in bottom of drawer in an organized fashion. They always fall off the racks.
Good luck finding one with the right # of slots for your wrenches too....
/ Harbor Freight Tools that don't suck #10,151
Or having the right tool and you have to fix it to fix something.
/ Harbor Freight Tools that don't suck #10,152
The reason I'm buying these is because I have more wrenches than can fit in the 2 54" x 22" drawers while laying flat. So to help stop the insanity, I need to have them held at an angle with some overlap.
/ Harbor Freight Tools that don't suck #10,153
Just buy another toolbox! Just kidding, kinda.
/ Harbor Freight Tools that don't suck #10,154
Can I get your home address please? I'm going to need a new place to live after I go but another toolbox and my wife cuts my nuts off and tosses me out.
/ Harbor Freight Tools that don't suck #10,155
Bring your tools and tool boxes :drink:
/ Harbor Freight Tools that don't suck #10,156
If these don't work out how about cutting angled grooves in a piece of plywood? You can control plywood size, groove angle and width to match your tools. May even be able to strategically place magnets underneath to keep the wrenches and wood in place.
/ Harbor Freight Tools that don't suck #10,157
Keep us posted, I'd like to see how this thing works for you. I can see it being useful.
As for the HF paddle switch grinder mentioned elsewhere, the safety fell off of mine and the switch sometimes stays on by itself. I like that grinder the least of all the grinders I have including the $10 ones. It also picks up dirt from the ground if you set it down while it's still spinning which means it sand blasts you when you turn it back on. Hard to beat the ten dollar ones at that price.
/ Harbor Freight Tools that don't suck #10,158
This is exactly why I wanted a service bed when I bought my last truck. Wife shot down the idea. So I’m stuck with a full toolbox in a truck so tall I can’t see in the toolbox of. And I mean full. If something isn’t right the lid won’t shut. I keep wanting to add a drawer stack for the common stuff. But haven’t found one with consistent good reviews.
Harbor Freight is building a new store in Owensboro, KY. That will be my closest one once complete.
/ Harbor Freight Tools that don't suck #10,159
Did a little more organizing this evening.20181107_211754.jpeg20181107_211806.jpeg20181107_211831.jpeg
/ Harbor Freight Tools that don't suck #10,160
I guess that's why HF has sold them for so long.
I have several angle grinders from various vendors and noticed the other day, the button that locks the shaft has broken or fallen out on two or three.
PENDING SELLER CONFIRMATIONS (A59905)
PENDING SELLER...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
2011 Mercedes Benz GL AWD SUV (A59231)
2011 Mercedes Benz...
2002 International 9200i Truck (A61306)
2002 International...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
