Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #8,621
I dunno. I have one of their 21° framing nailers and have had no problems with it. Doesn't seem to double-fire as often as a friend's name-brand one (forget the brand of his). If I was a pro carpenter I might think twice, but for the occasional home project, building a shed, etc. it does the job.
I have heard that HF's nails tend to jam, I get mine at HD or Lowes and they're fine.
I bought their 18 Ga pin/staple nailer. Ran about 200 pins and a few staples through it. The spring loaded follower that feeds the pins has jump out of position 4 times requiring disassembly to fix. Tired of that I bought a Hitachi at Lowes; drives pins only. I am taking the HF nailer back along with their table saw and dado set (I reported this in an earlier post), propane tank mount heater (use 3 times and the auto valve fails to open), and belt sander (defy anyone to install the dust bag). I will continue buying there but?
Ron
/ Harbor Freight Tools that don't suck #8,622
Ron
The long term reliability question, is the very reason I shied away from the new HF MIGmax 215 inverter welder last month.
It initially seemed like a good idea, and it carried a one year money back warranty.
But, the question became...... what to do when it might fail, sometime after the 12th month?
The extended warranty was rather expensive, and was only available for another two years max.
I was not willing to risk loosing $650+ tax.
Bought a 240V Hobart Handler 190 MIG instead. Not a light weight inverter machine, but an established/reliable (Miller/Hobart), transformer type, and with product support readily available from Hobart, in Troy, Ohio.
/ Harbor Freight Tools that don't suck #8,623
I'm seriously thinking about purchasing either the 44" (~$350 14,200ci) or 56" (~$650 25,363ci) tool box while they're on-sale tomorrow.
I keep going back-and-forth between one of them and waiting to see what shows up at Costco.
Today I have most of my stuff spread between a HF 26" (~$300 14,600ci) & 30" cart (~$150 8100ci) and a Seville Classics UltraHD 12-drawer rolling workbench and a couple different physical locations.
If you've got room buy both!
I bought a blue 36" Husky tool box
and need a rolling cart to go under it, and I'm having a difficult time deciding between 44", 56" or go whole hog for the 72".
Newbury, I have all five of the Lynxx tools, all bought within the last six months. Very impressed with them. The standard 20% and 25% coupons don't work on them, but they go on sale every few weeks, and occasionally there is a $20 off Lynxx coupon in the flyers and monthly catalogs (e.g., the March 2018 catalog).
Thoughts as follows:
Pole chain saw - This is a real winner. I reviewed it in this thread at page 820, post 8197, and on the HF website. Only weakness, IMO, is that the 10 mm circlip that secures the drive sprocket on its hub is a bit weak. Easily replaced with better spring steel from Fastenal for a few cents.
Blower - Remarkably powerful. Also has a "Turbo" button for high velocity bursts. A helper used it to blow the leaves off our entire front yard in about 1-1/2 hrs. Even on Turbo, the thing will run for 1/2 hr! My wife just took him a freshly-charged battery to swap out when he needed it. Battery is very quickly charged, and they're all interchangeable across the tool line. Five tools means five batteries and five chargers. :dance1:
24" edge trimmer - Very versatile. Easily slices through 3/8" and 1/2" woody stems when necessary. Out performs both of my corded hedge trimmers.
14" chain saw - I was very skeptical about this one, but it's now my go-to saw for quick stuff instead of my little workhorse 14" Stihl L009 climbing saw. Not as powerful, of course, and it has a thinner chain (and it's micro-chisel) but easily handles limbs and trees up to 8" caliper. Probably much more if you're careful, but I haven't tried. Fallen tree limbs blocking the driveway overnight and making you late in the morning? No problem, just grab the saw, pop in a battery, and start cutting. No messing with fuel mix, and no fumes, so don't even need to change clothes first. The saw also stops instantly when you let up on the trigger. That's a safety plus when working in tangled brush.
String trimmer - This is the weakest performer of the five, IMO. But still worth the $$ on sale. Wife loves it for light trimming (grass and non-woody stuff). Doesn't begin to compare to a good gas trimmer, but sure beats the hassle for quick touch-ups. The line is very thin, .065", but even so, the spool only holds 20' of it. Couldn't go heavier, and even if you could, I suspect it would degrade performance rather than enhance. But it comes with two spools, with the second one stored onboard in the trimmer head itself. The line feeds automatically each time you release the trigger, i.e., each time you stop. Not by bumping the spool as in gas units. This is a bit of a nuisance But you can manually feed line by pressing a release button on the spool.
The angle of the trimmer head has several different positions, so it can be adjusted for edging. It comes with an "edger" attachment that snaps on and off, consisting of two lightweight plastic wheels to support the trimmer head as it's rolled along a pavement edge. A bit gimmicky, unless you have a lot of vertical edging. Doubt we'll ever bother with it again.
THANKS! for the data points.
/ Harbor Freight Tools that don't suck #8,625
I'm thinking of buying the 14" woodworking band saw. It seams to just be a clone of the other brands of 14" band saws on the market. It's less than half the price of a Grizzly (since I can pick one up at a store and use a 20% off coupon) but doesn't include a fence and other features. I've read a lot about people who have added things to them to make them nicer. A lot of the stuff I have read are older posts. Often more than 5 years old. It seams like it's hit and miss. If you get one that was made well it's easy to upgrade. If it's not then you will struggle. Does anyone have one? What's your opinion of the saw?
/ Harbor Freight Tools that don't suck #8,627
Has anyone bought and used one of the rolling tool carts? 3� in. Bulk Storage Tech Cart ? It goes on sale this weekend and I was thinking it would be good to store air tools and supplies in for working on the cars/trucks and tractors. Easy to move to the driveway.
The smaller tool chests go on sale this weekend too. 3 in. 5 Drawer Mechanic's Cart - Blue
/ Harbor Freight Tools that don't suck #8,628
Personally I like the 5 drawer.. a 2 drawer USED on the Snap-on truck is around 500.00
1 of the handiest things to add on to it, & I haven't seen a HF dedicated one yet, is the screwdriver rack..
I KNOW snap-on has them w/ a closable & lockable cover.. holds about 10 screwdrivers & prybars..
Also, the fold out side table.. its a pita to keep shutting the lid to hold a manual or write on something flat..
/ Harbor Freight Tools that don't suck #8,629
No, but I have the other one: 3 in. 5 Drawer Mechanic's Cart - Black
and it's great, unfortunately, I need about 3 more of them...
:confused3:
But mine didn't come with the little tray on the other end from the handle.
Putting it together was kind of a PITA but only because of trying to work in the close spaces- and for once it came with extra hardware- at least 2 or 3 extra bolts, washers and nuts.
/ Harbor Freight Tools that don't suck #8,630
Can I use the 20% coupon on the $749 US general 56" toolbox to get it for $600…? Or is US General somehow excluded from the coupon?
/ Harbor Freight Tools that don't suck #8,631
If I recall the magnifying glass print excludes tool storage, engines, air compressors, or any other big ticket items that would cost them lots of lost money.
/ Harbor Freight Tools that don't suck #8,632
/ Harbor Freight Tools that don't suck #8,634
So basically, anything that "doesn't suck" is excluded?
/ Harbor Freight Tools that don't suck #8,636
Took our Odyssey minivan to buy the 1,000 lb motorcycle lift as it’s on sale this weekend. The store I went to would only load it with a forklift into a pickup truck.
The box is 340 lbs and 89” long and the cargo area over 90”. Have to go to another store that understands material handling.
/ Harbor Freight Tools that don't suck #8,637
You'll notice all sorts of new HF "brands" used for lines of tools. They have unique new brand names for meters, hand tools, welding supplies, power tools, etc. Now look at the newest coupons, and you'll see they list every one of these new brands in the fine print as excluded from coupons.
/ Harbor Freight Tools that don't suck #8,638
I suspect it's an OSHA or insurance rule so employees don't potentially injure themselves loading large, heavy boxes into customers' vehicles.
Maybe borrow a truck from a friend?
/ Harbor Freight Tools that don't suck #8,639
I don't understand why so many here have such a problem with restrictions on the 20% off coupons. Plenty of items that they DO work on. Name one other store that allows customers to get a discount on the item of their choosing.
Many/most of the excluded items go on sale periodically.
/ Harbor Freight Tools that don't suck #8,640
I saw the list, but "tool box" is not listed. So I figured I'd ask the collective brain instead of driving a half hour to try it.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
UNUSED FUTURE PG72-72" HYD PLATE GRABBER (A60432)
UNUSED FUTURE...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
BUNDLE OF METAL FRAMING BRACKETS (A60432)
BUNDLE OF METAL...
402 (A52706)
402 (A52706)
2017 Ford Transit Connect Cargo Van (A59230)
2017 Ford Transit...
