Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #12,091
OK. My 8750W was around 200 Lbs and came by truck. My little 2K inverter was probably 50-60 though.
It is the EU2200... I have bigger and smaller... 25 year old EM 5000 and 30 year old 1000 that currently has a carb issue... darn CA ethanol...
Update... just drove up and Generator delivered.
   / Harbor Freight Tools that don't suck #12,092
I've wondered if a better substitute to grind apples would be to buy a brand new garbage disposal, sterilize it with bleach, then core the apples and run them through that. Anybody ever try this?
(My attempt to hull walnuts in HF's junior cement mixer was a complete waste of time).
The only issue is that the disposals rely on constant water flow to keep them from clogging.
Is you want "apple flavored juice" it could work.
   / Harbor Freight Tools that don't suck #12,093
You could always use apple juice instead of water to keep things flowing. I've also seen a DIY margarita machine made out of a new garbage disposal.
Ok, actually dug up the link again too... The Margarita Machine looks like it will pump liquid and/or a slushie up over a foot.
   / Harbor Freight Tools that don't suck #12,094
Interesting. Would it be recycling it's own juice? I guess you would need a "start up" batch to get it going.
And just how fine will the disposal grind the apples? Will one trip through the disposal be enough?
   / Harbor Freight Tools that don't suck #12,096
My neighbor across the lane just told me she bought a restaurant-grade garbage disposal (new) and ran 500 lbs of apples through it making cider.
   / Harbor Freight Tools that don't suck #12,097
Does anybody REALLY want a >>*white*<< tool cart?
I mean, unless you're running a clean room for some reason.
My vision isn't the best and I've built several tool storage trays over the last few years. The inside of all of them have been painted white to help me see the tools.
   / Harbor Freight Tools that don't suck #12,099
HF aint the only ones with white toolboxes. Lowes has them now also. Apparently you were ahead of the curve on this one.
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A57453)
2015 Freightliner...
30in Forks and Frame Mini Skid Steer Attachment (A56857)
30in Forks and...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
1994 Oldsmobile Cutlass Supreme (A57148)
1994 Oldsmobile...
2004 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2004 Ford F-150...
Giyi Telescopic Boom (A57149)
Giyi Telescopic...
