Harbor Freight tools that DO suck
Status
Not open for further replies.
/ Harbor Freight tools that DO suck #221
Not so much a single tool or item, but their policy that was changed a few years ago. No more individual sockets or wrenches, only sets. Makes it a bugger if you lose one, or need a special size.
Is that in reference to broken sockets of the impact variety? I was told by the local store manager that if I broke one, they would replace the broken one (lifetime guarantee). I've tried, believe me, but I cannot break them. Broke MAC's, Snap-On, SK and Cracksman but never HF.
/ Harbor Freight tools that DO suck #222
Slotted heads are fine if you use the correct width screwdriver. I work on firearms a lot and most action screws are slotted. I have a set of slotted bits I use but I make sure the bit is the correct width (and length) for the screw. I prefer Torx over everything else but alas, action screws aren't.
My complaints with slotted screws tends to be more on wood screws than bolts. It seems a lot of them have very shallow slots so the blade slips out if the screw is really tight. Don't really lend themselves to using a drill/driver either.
What would they do if you did break one since they no longer sell individual sockets, replace the whole set or "borrow" one from a set on the rack? I do seem to see quite a few socket or wrench sets in the bargain bin with one piece missing...maybe that's why?
/ Harbor Freight tools that DO suck #223
Have not broke one as of yet and I've tried. I guess if I do, I'll find out then. Until then it's only conjecture. Maybe I need to take one of the 1/2" drive impacts and put a 1/2 to 3/4 impact adapter on it and use my 3/4 drive extended anvil truck impact wrench to loosen something and see if I can fracture one that way. My IR 1/2" 1300 foot pound impact running at 175 psi won't do the deed.
HF does offer a 3/4" drive impact socket set with a double ended bud wheel socket but I have no need, already have a MAC set.
On the subject of HF not to buy stuff... No rubber bands (tarp straps) from HF. Still Chinesium self destructing rubber. Lasts 6 months and crumbles.
/ Harbor Freight tools that DO suck #224
Bought the HF pneumatic grease gun for $29.95.
Tried to make it work.
Bought a Lincoln pneumatic grease gun for $65, and threw the HF one away.
What he said^^
I did the same thing. When the pressure chamber screws backed out of the HF (1 was missing and the other 3 were very loose), I took it back. It was beyond refund, but I wanted to point out the safety hazard to HF. The manager could not care less, just kept saying I couldn't get a refund even though I told her that I knew that up front. :confused3:
I am much more selective about what I buy at HF since that experience!
/ Harbor Freight tools that DO suck #225
The chisel/punch set sucks! I have lots of HF stuff and a fan of most of it, but stay away from these. Obviously not hardened steel.
Haven't read all this thread, but my opinion of their files is the same. Good for wood and plastic, but not for iron.
/ Harbor Freight tools that DO suck #226
I buy my air greasers from Tractor Supply and get the one year extended warranty. Just before it's up I call and tell them warranty company)'it's broken and then they send me a voucher for a new one. I have gotten 3 that way and paid for one. Easy to fix so I have 2 spares I keep different greases in. Manager set me wise to the scam btw.
They don't want the old broken one back so I keep and fix it.
/ Harbor Freight tools that DO suck #227
I've sold my homing pigeon 37 times so far...!
/ Harbor Freight tools that DO suck #229
Another policy thing. READ your new coupons very, VERY closely. The 25% Off Friends and Family I got recently has added Central Machinery to the exclusions list. The previous 25% off one I got a few weeks ago did not. I don't know if this is a one time exclusion, or a permanent change. CM is one of their staple brands though for many of their motor driven tools.
/ Harbor Freight tools that DO suck #231
Could be. Think I'd return the whole set but I have not broken one yet.
/ Harbor Freight tools that DO suck #232
One HF stuff that sucks, their rubber tarp straps suck big time. One, they stink, Two, the don't last (fall apart) and Three, the hooks pull through the rubber part easily.
Total junk.
/ Harbor Freight tools that DO suck #233
Total junk.
Yea they do. I had a few new ones wrapped around a air conditioner cover and didn't even last the winter without cracking and breaking.. I wouldn't even get them if they offered them with the free coupons.
/ Harbor Freight tools that DO suck #234
I bought a bunch of HF dollies on sale. The little 12x18's and some 18x30's. All supposedly rated for 1000 lbs. I had my doubts, but lots of people use them and they're cheap, so why not?
Lol, here's why not: DSCN2682.jpg
Turns out the "wood" hiding under those black covered ends is just thin plywood withs some veneer:
It broke under one corner of a 745 lb rotary cutter when I was setting it down. To be fair, the cutter did drop hard the last inch or so (but there were three supporting endpoints, one being the rear wheel).
The way I ended up using it was like this: DSCN2681.jpg
with the wood piece in the opposite direction of the one that broke.
So... some dollies have survived their first day of use, others ... not. Live and learn, managing these tractor tools is all new to me. Meanwhile it's been 2.5 weeks and I'm still waiting for the 18x30 dollies, which are in stock per repeated phone calls but HF cannot seem to get their act together. Last time I buy from them mail order I think.
/ Harbor Freight tools that DO suck #235
put them on proper pallets and move them with forks.
i think you were asking a but much from that. the dollies i have hold up fine with a large old drill press or a 5.3L cast iron Chevy on them, but not on a point load like that.
/ Harbor Freight tools that DO suck #236
The weight needs to be evenly distributed across the carpeted sections and on top of the casters. The crossbars between are just that, crossbars/stringers, not intended to be weight bearing.
/ Harbor Freight tools that DO suck #237
Those castors on the dollies are garbage. #1000lb rated?? maybe on the moon.
/ Harbor Freight tools that DO suck #239
Good point, only the carpeted parts are weight-bearing. Like anything from HF take the rated capacity then don't exceed 2/3 of it. :)
I haven't had a problem with those. I prefer those over the larger ones rated the same weight.
There is a version of the dolly that is pure junk - the all-plastic replicas of that small one which are rated 200 lbs. I broke one of those the first day I had it. So I took it back for a replacement. No problem, go get one from the display. Before taking the replacement to the register I tested it - and broke it standing on it with just a slight bounce. I weight 180 lbs. The 200 lb rating for the plastic ones is bogus. The 'rating' seems to be the tested breaking strength.
/ Harbor Freight tools that DO suck #240
The space shuttle probably only weighs 1,000 pounds on the moon,,
will it fit on one of those casters? :confused: :confused2:
:D
Status
UNUSED ATSPOWER PLASMA CUTTER (A64281)
UNUSED ATSPOWER...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2004 International 8600 Tender Truck (A63688)
2004 International...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2019 JCB 2TS-7T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 2TS-7T...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
