Hanging finish mower
/ Hanging finish mower #1
JT94
NE Ohio
Kubota L3000DT
Hello all,
Somewhere, sometime before I read that someone hung their finish mower in their barn/garage for storage. I tried doing a search, but no luck.
Since I won't be mowing any snow covered lawn this winter, I was thinking about hanging the mower from the rafters using a "come-along" type system. My question is has anyone done this already and does anyone know if rafters will hold a 5' pull behind finish mower.
Thanks!
/ Hanging finish mower #2
JT94
A 60” mower would weigh around 3 to 400 lbs. /w3tcompact/icons/eyes.gif That would be a lot of weight to hang from rafters without reinforcement of the rafters to the floor.
/ Hanging finish mower #3
I remember the post concerned a BX2200 mid mount mower. It was actually hung on a wall with one section resting on the floor. There was a picture of the arrangement. If I recall correctly, it had one side on the floor (the mower being wider than long).
As far as hanging your mower from a come-along..that's a lot of weight concentrated in one spot...not a particularly good idea.
I suggest you look into propping it up against a sside wall somehow instead.
Actually I was thinking about running a chain around 3 of the rafters....but still probably not a good idea.
I guess I was fishing to see if anyone has done something similar to this. Proping in up on end is a good idea, though. My only concern would the gear oil leaking out.
Thanks anyhow for the replies!
/ Hanging finish mower #5
Mike -- I don't have a comealong, but at the end of the year I roll my LP 2572FDR to the back of my garage and use the FEL to stand it on its tail before using a pair of straps to secure it in that position. All the weight is on the floor, with the straps just keeping it there in case it gets bumped. For safety, I also chock the bottom edge. That position, as luck would have it, has the seals aimed straight up so leakage isn't an issue; it's also great for servicing the blades and baffles.
Pete
/ Hanging finish mower #6
I hang my 6' MMM deck from a beam in the basement of my shop. I use a chain fall to hoist it up. The vent is on the high side so I get no leaks. Works great for getting more floor space. See attached photo.
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
2025 Hydraulic Auger Bits Mini Excavator Attachment (A61572)
2025 Hydraulic...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
2016 Cadillac CTS Sedan (A61574)
2016 Cadillac CTS...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
