Hand Pump suggestions
/ Hand Pump suggestions #1
tyr382
Non
Need to build a DRC charging kit.
Basically just need a hydraulic hand pump that can get up to 20bar without introducing any air in the system at all.
This is the device I need to make
If anyone has any other suggestions on what kinda of pump and manifold I need would be much appreciated
Closes I can get to a pump are these types
/ Hand Pump suggestions #2
You can get a hand pump for cartridge valve cavities. HydraForce (HP10-21 or HP16-21), Bucher (CMHP-10), etc. ISZ
/ Hand Pump suggestions #3
Automotive body shops use a hand powered pump to pull/push damaged panels all the time.
Self contained and they looking similar to a grease pump.
/ Hand Pump suggestions #5
Check out McMaster Carr, they have all kinds of options for hand pumps. Stay away from the Portopower types those are rated for 10,000 psi and not made the same quality as the one pictured above.
/ Hand Pump suggestions #6
Manual Pump for Leak Testing and Calibration, Portable, for Water and Hydraulic Fluid, 363 PSI
McMaster-Carr
20 bar would be 294 psi, so this would work.
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
KMC Strip Till Rig & Planters (A64126)
KMC Strip Till Rig...
John Deere 4520 (A60462)
John Deere 4520...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
Unverferth Perfecta 12 (A64126)
Unverferth...
