hand-operated compactor
/ hand-operated compactor #1
bky
Northern Kentucky
l245dt
I am in the process of installing a stacked blocked wall and while reading the direction about compacting behind each course they say to us a hand-operated compactor. Does that mean the type with a wooden handle with a steel plat or are they talking about a plate compactor.the link may explain it better.
Thanks Bill
steep #7 http://www.anchorwall.com/cmsVirtua...mond Pro Installation Instructions-WPV850.pdf
/ hand-operated compactor #2
Plate Compactor. They show one in the bottom left image. They are trying to make sure you don't use a self-propelled roller or some monster compactor that will tip the wall over. Personnaly, up to four or six feet high, I don't compact the fill unless I'm over a layer of geogrid.
-rus-
Thanks Rus, I saw the picture with the compactor in it but I didn't want to harm the block or the stability of the wall not using the proper tool. so you wouldn't recommend compacting the stones in the hollow cores or the back of the wall?
/ hand-operated compactor #4
Stone is typically at .95 compaction at placement, so you won't gain much, if anything trying to compact that. They are talking about compacting the fill dirt that goes behind the drainage stone. It is a judgement call as to whether that should be compacted and depends on the type of soil, moisture content at placement and other site conditions. If you're putting a parking lot behind the retaining wall, I would compact in six inch lifts. If this is just going to be a garden or yard space behind the wall, slight settling is less of an issue.
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
199 (A64278)
199 (A64278)
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2016 KENWORTH T680...
