Hand and foot throttle problem
/ Hand and foot throttle problem #1
remurden
Chesapeake, VA
Yanmar 1610D
Need some help with that looks like to be a simple setup. I have a YM1610d. I can use the hand throttle and pull back to increase speed but when i push back on the hand throttle to decrease speed the foot throttle does not come up and the hand throttle just has free play. I have to stick my foot under the foot throttle and pry it up to decrease speed. Any thoughts on how and what i need to get these two throttles working together?
Thanks,
Richard
/ Hand and foot throttle problem #2
Take a look at the linkages, sounds like something is binding up. Probably nothing more than bending a linkage straigth with a pair of pliers and some WD-40.
/ Hand and foot throttle problem #3
Dieselfuelonly has it right
Its lubrication where the throttle handle comes out the side, lube the 2 friction discs and the linkage between the two.
Also the foot throttle cable.
These are an easy fix with a can of spray.
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2022 Weber CR 5-II HD Reversible Plate Compactor (A61572)
2022 Weber CR 5-II...
3143 (A63117)
3143 (A63117)
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
