Hand and foot throttle problem
/ Hand and foot throttle problem #1
remurden
Chesapeake, VA
Yanmar 1610D
Need some help with that looks like to be a simple setup. I have a YM1610d. I can use the hand throttle and pull back to increase speed but when i push back on the hand throttle to decrease speed the foot throttle does not come up and the hand throttle just has free play. I have to stick my foot under the foot throttle and pry it up to decrease speed. Any thoughts on how and what i need to get these two throttles working together?
Thanks,
Richard
/ Hand and foot throttle problem #2
Take a look at the linkages, sounds like something is binding up. Probably nothing more than bending a linkage straigth with a pair of pliers and some WD-40.
/ Hand and foot throttle problem #3
Dieselfuelonly has it right
Its lubrication where the throttle handle comes out the side, lube the 2 friction discs and the linkage between the two.
Also the foot throttle cable.
These are an easy fix with a can of spray.
Kubota GR2020G (A63688)
Kubota GR2020G...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
1995 John Deere 7400 (A60462)
1995 John Deere...
2022 EZ-GO ELITE...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
