Hammer drill
/ Hammer drill #11
I would never run any hammer drill, toy or not without the side handle. All you do is take a big chance on breaking your wrist should the bit grab in the hole. I actually had my Bosch pick me up off the ground one time and spin me around. Only thing that saved me was it unplugged itself.
/ Hammer drill #12
And amazing how fast a drill can spin a 200 lb object..
/ Hammer drill #13
@fatjay don't get me wrong, I love Milwaukee tools, but I'm not sure that this is the best tool for the job.
If you want to drill more than a hole or three, I would strongly urge you to get a drill that is either SDS-Plus or SDS-MAX.
I have a couple of drills like your Milwaukee, and I agree @Slowpoke Slim and @bigtiller that there is really no comparison. I feel like my little "hammer" drill is a three year old kid going "Vroom! Vroom!", rather than getting the job done. Using the SDS drills feels like drilling wood with a regular drill; the pile of sand/dust just flies up out of the hole. As an added bonus, I find that the SDS drills don't wear out the carbide tips anywhere near as fast as the non-SDS drills.
The bigger drills have an actual hammer that is plunging in and out. The Milwaukee 5376-20 just has a ridged plate that a second plate rotates on. (4h and 11a in the service manual below) Yes it is a "hammer" motion, but the force is lacking...
https://documents.milwaukeetool.com/54-24-3660.pdf
All the best,
Peter
I agree 100 percent. My old “hammer” drill hasn’t been used since I got a SDS hammer drill.
/ Hammer drill #15
You could rent a sds from the depot.....
/ Hammer drill #16
If I use a regular masonry bit that goes in a jacobs style chuck, will the hammer function cause excessive wear on the chuck/bit?
Way back when, i bought a corded Milwaukee hammer drill with a keyless chuck. First time using it, I had to wonder who was dumber, me or Milwaukee? I changed it out to a used keyed chuck which held up until the motor died.
/ Hammer drill #17
I wouldn't worry about that. I have several 1/2 hammer drills that we used on thousands of plumbing jobs and they still have the original chucks
/ Hammer drill #18
I never had any luck with anything but an SDS bit hammer. Good advice on the side handle. Plus, I always orient my hands so that the fingers are away from the rotation. i.e., so your fingers open up if the hammer grabs. That has helped me quite often.
/ Hammer drill #19
Every DIY'er will need a rotary hammer sometime in his life. SDS Plus should get most jobs done. The increased power and size of bits of SDS Max is nice, but a bit too high for me.
The best thing about a rotary hammer is no pushing. Just let the weight of the drill motor do the work. All you have to do is guide it.
+1 on that!! I wish I'd known about rotary hammers about 5 years ago when I built some stone steps and had to cut a couple pieces of granite. Man, it took forever to drill the holes for the feather wedges with an ordinary masonry bit and a hammerdrill.
/ Hammer drill #20
That is the difference. I do only cinderblock, hammer drill for me is fine, did a few hundred, no issues.
Solid cement, stone block, SDS would be worth the extra, even for a few holes.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2019 BOBCAT T740 SKID STEER (A62129)
2019 BOBCAT T740...
Ford 8210 (A60462)
Ford 8210 (A60462)
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
Kubota U55-4 (A57148)
