Half scale replica of a John Deere H
   / Half scale replica of a John Deere H
Projected got pushed to the side with us moving and my mother passing away, hope I will now get sometime to work on it again.
Got some work done on the steering shaft, installed grease fitting & square up and welded the socket extension in place.
   / Half scale replica of a John Deere H #22
Glad its getting back to normal for you :) ...keep the updates coming on the project.
Got the steering shaft welded to the pedestal. mounted a gas tank and got the little bugger running for the first time in about 20 yrs. A lot of smoking at first but that has seemed to have gone away. Even took it for a drive through the subdivision. Here a couple of really short videos of the engine running. Maybe I can find someone to tape me driving it around.
You can see the flywheel turn in this video.
You can see the clutch pulley turning a little here, it is just held on with a clamp right now.
   / Half scale replica of a John Deere H #25
It's looking good.
Here's a video of me driving it around the back yard. Using a screwdriver to tighten the belt pulley as I do not have the hand clutch arm installed yet. Figuring out how the hand clutch is going to move the pulley into position will be a challenge.
   / Half scale replica of a John Deere H #27
I'm not sure the dog likes it as much as you do:D
   / Half scale replica of a John Deere H #28
so did the thread die out. i was enjoying this. and how does the rollers turn on the sides. is that a pto or do they just spin when your in gear.
Haven't had much time to work on it, hope to get back to it soon. Flywheel spin through a gear box when motor turns and the roller as you call it engages when the hand clutch is engaged.
   / Half scale replica of a John Deere H #30
Looks like the dog isn't too fond of it.
I wonder if you could find a gang reel mower for it?
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
Bush Hog RDTH84 (A57148)
Bush Hog RDTH84...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
5TH WHEEL PLATE (A58216)
5TH WHEEL PLATE...
Case-IH 586G (A57148)
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
