Half scale replica of a John Deere H
   / Half scale replica of a John Deere H
Projected got pushed to the side with us moving and my mother passing away, hope I will now get sometime to work on it again.
Got some work done on the steering shaft, installed grease fitting & square up and welded the socket extension in place.
   / Half scale replica of a John Deere H #22
Glad its getting back to normal for you :) ...keep the updates coming on the project.
Got the steering shaft welded to the pedestal. mounted a gas tank and got the little bugger running for the first time in about 20 yrs. A lot of smoking at first but that has seemed to have gone away. Even took it for a drive through the subdivision. Here a couple of really short videos of the engine running. Maybe I can find someone to tape me driving it around.
You can see the flywheel turn in this video.
You can see the clutch pulley turning a little here, it is just held on with a clamp right now.
   / Half scale replica of a John Deere H #25
It's looking good.
Here's a video of me driving it around the back yard. Using a screwdriver to tighten the belt pulley as I do not have the hand clutch arm installed yet. Figuring out how the hand clutch is going to move the pulley into position will be a challenge.
   / Half scale replica of a John Deere H #27
I'm not sure the dog likes it as much as you do:D
   / Half scale replica of a John Deere H #28
so did the thread die out. i was enjoying this. and how does the rollers turn on the sides. is that a pto or do they just spin when your in gear.
Haven't had much time to work on it, hope to get back to it soon. Flywheel spin through a gear box when motor turns and the roller as you call it engages when the hand clutch is engaged.
   / Half scale replica of a John Deere H #30
Looks like the dog isn't too fond of it.
I wonder if you could find a gang reel mower for it?
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
John Deere 8650 (A57148)
John Deere 8650...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
1999 NUTTALL 53FT FOUR AXLE HEAVY HAUL TRAILER (A58214)
1999 NUTTALL 53FT...
CFG Industry MH12RX Mini Excavator (A57149)
CFG Industry...
1999 FREIGHTLINER FLATBED (INOPERABLE) (A58214)
1999 FREIGHTLINER...
