Half scale replica of a John Deere H
   / Half scale replica of a John Deere H
Projected got pushed to the side with us moving and my mother passing away, hope I will now get sometime to work on it again.
Got some work done on the steering shaft, installed grease fitting & square up and welded the socket extension in place.
   / Half scale replica of a John Deere H #22
Glad its getting back to normal for you :) ...keep the updates coming on the project.
Got the steering shaft welded to the pedestal. mounted a gas tank and got the little bugger running for the first time in about 20 yrs. A lot of smoking at first but that has seemed to have gone away. Even took it for a drive through the subdivision. Here a couple of really short videos of the engine running. Maybe I can find someone to tape me driving it around.
You can see the flywheel turn in this video.
You can see the clutch pulley turning a little here, it is just held on with a clamp right now.
   / Half scale replica of a John Deere H #25
It's looking good.
Here's a video of me driving it around the back yard. Using a screwdriver to tighten the belt pulley as I do not have the hand clutch arm installed yet. Figuring out how the hand clutch is going to move the pulley into position will be a challenge.
   / Half scale replica of a John Deere H #27
I'm not sure the dog likes it as much as you do:D
   / Half scale replica of a John Deere H #28
so did the thread die out. i was enjoying this. and how does the rollers turn on the sides. is that a pto or do they just spin when your in gear.
Haven't had much time to work on it, hope to get back to it soon. Flywheel spin through a gear box when motor turns and the roller as you call it engages when the hand clutch is engaged.
   / Half scale replica of a John Deere H #30
Looks like the dog isn't too fond of it.
I wonder if you could find a gang reel mower for it?
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
New/Unused Electric Golf Cart (A57453)
New/Unused...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
