Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,710
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Another thing you will want to think about is skidding a long hitch. Especially in winter with a small tractor like ours. When you have on a long hitch it acts as a rudder and makes it hard to turn. Before you start out make sure to flip the brake pedal lever so your steering brakes are ready to use. Chose a gear and set your hand throttle to give you good power your desired slow speed. That keeps the right foot free to to operate the brake steering, the diff lock, or the throttle pedal for more speed, whichever is appropreate. I use my steering breaks and dif lock a lot both summer and winter. But in winter it would be impossible w/o them in my woods.
One of my worst predicaments occured with this hitch about 100 feet after I stopped for this picture.
I tried to make a small right turn the tractor wanted to go straight. The left side of tractor came off the packed portion of the road and the two left tires dropped into deep unpacked snow. The tractor tipped left and was off the left side off the road with the front of the left rear tire and my shoulder up against a 12" tree. I could not back up with the hitch behind me. I could have cut the logs up and rolled them out of the way but I used a snatch block and pulled them backwards to free up the tractor. I couldn't move much because of the tree between the tire and foot step, I couldn't cut the tree because it was leaning towards the tractor. And the tractor didn't want to climb back up onto the packed trail anyway. I finally got out using the winch to pull back and side ways then going forward a little. It took several tries. When I finally got on solid ground my front left tire was flat. A branch in the snow had jammed bewteen the rim and bead. I managed to drive the 1/4 mile out of the woods on three wheels and luck.
So practice using your steering brakes and keep your hitches short til you get a feel.
gg
gg
