Chains Had to put the front chains on
   / Had to put the front chains on #31
The trick to the gravel is, pack down the first 4 inches of snow. And, don't use chains, or spin your wheels.
Any wheel spin, brings the gravel up to the top.
With care, I manage to only move about a 5 gallon bucket of gravel each winter. Which sure beats raking it out of the grass every spring.
   / Had to put the front chains on #32
Have studded chains and the backhoe on ,and was trying to up this slight hill in the back yard. The hill is on an angle sloping away from where I wanted to go, I thought it would be not problem, but in 4wd the front end was just starting to slide down hill and not in a direction I wanted or needed to go!. I stopped backed up and put the 2 link twist chains for the fronts on. Tried again it it was much better, I think the tractor is just not heavy enough at times,. You can see my tracks in the pics
Sent from my iPad using TractorByNet
I dont use or need chains, I just fill the FEL with dirt or cinder blocks and it gives me all the traction needed. If it still gives you a problem I concur with another poster about driving up backwards.
   / Had to put the front chains on #33
i had to chain up all 4 a few weeks ago. the tractor was just sliding too much. dont like the feel of loss of control when plowing. works soo much better with the chains
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
(2) UNUSED FUTURE 6' CLIP-ON FORK EXTENSIONS (A58376)
(2) UNUSED FUTURE...
20' Shipping Container (A57149)
20' Shipping...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2008 40ft T/A Gooseneck Flatbed Equipment Trailer (A56858)
2008 40ft T/A...
