Chains Had to put the front chains on
   / Had to put the front chains on #31
The trick to the gravel is, pack down the first 4 inches of snow. And, don't use chains, or spin your wheels.
Any wheel spin, brings the gravel up to the top.
With care, I manage to only move about a 5 gallon bucket of gravel each winter. Which sure beats raking it out of the grass every spring.
   / Had to put the front chains on #32
Have studded chains and the backhoe on ,and was trying to up this slight hill in the back yard. The hill is on an angle sloping away from where I wanted to go, I thought it would be not problem, but in 4wd the front end was just starting to slide down hill and not in a direction I wanted or needed to go!. I stopped backed up and put the 2 link twist chains for the fronts on. Tried again it it was much better, I think the tractor is just not heavy enough at times,. You can see my tracks in the pics
Sent from my iPad using TractorByNet
I dont use or need chains, I just fill the FEL with dirt or cinder blocks and it gives me all the traction needed. If it still gives you a problem I concur with another poster about driving up backwards.
   / Had to put the front chains on #33
i had to chain up all 4 a few weeks ago. the tractor was just sliding too much. dont like the feel of loss of control when plowing. works soo much better with the chains
AGT Industrial SDA-140W Mini Skid Steer (A57149)
AGT Industrial...
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
Survey Kit (A57149)
Survey Kit (A57149)
1980 PULLMAN DRYVAN (A58214)
1980 PULLMAN...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (INOPERABLE) (A58214)
AM GENERAL M1123...
