H&H Manufacturing Toothbars
   / H&H Manufacturing Toothbars #1
robertm
Veteran Member
Northern Illinois
Kubota BX2660
Well, I hate to be this way, but I think H&H needs to get a wake-up call. Years back, I ordered a toothbar from H&H because I liked the way their toothbar had a wrapped v-edge that protected the factory bucket edge when compared to the Markham toothbar. Now that I sold the Kubota B7510, I kept the toothbar for my BX2660 as the buckets have the same dimensions. I went to H&H's website and see they have a wear edge (straight) that I'd like to put on my BX while the bucket is new, and hopefully line up the mounting holes with my tootbar so I can readily change them out. Simple, right? NOT!
I have tried to call many of their distributors in my area, and IF they are in business, the distributors say "H&H Who?" I even sent an email yesterday and one today, but I'm at a dead end. If I had a welder, it'd be a different story, but I don't. I rather not just order a standard 66" flat wear edge, cut it down, and plow bolt it to the factory edge. I was hoping to make this work via H&H, but they have a poor network. I think that anyone who bought from them in the past became "a dealer".
   / H&H Manufacturing Toothbars #2
Sounds like you need to find a welder. Someone you can drop off small parts. It might even be cheaper than buying
My dad always had a guy he would go see to get things welded up for the farm.
Now I have a welder and I use it every time I go out in the garage.
   / H&H Manufacturing Toothbars #3
Call me. I might be able to help you.
Nelson
W. R. Long Inc.
Finally got a response from two distributors of H&H. OUCH! WOW! $450 for a wear edge? I can get a bolt-on wear edge AND tootbar from WR Long that will share the same mounting holes for that kind of lettuce. I'm going to sell my 48" H&H toothbar to recoup a few bucks, and get the WR Long equipment. I think the H&H is much more heavy duty, but I dont need it for ripping rocks and stumps. I mostly need the wear edge to wear against the asphalt and keep me from bending the cheap cutting edge that comes from the factory. What is a good priceto put on a slightly used toothbar if it sells for $450 new?
Propane Tank and 2 Oxygen Tanks (A57454)
Propane Tank and 2...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A57453)
New/Unused AGT...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2013 Ford F-750 Truck, VIN # 3FRXF7FL2DV789551 (A57453)
2013 Ford F-750...
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
