H&H Manufacturing Toothbars
/ H&H Manufacturing Toothbars #1
robertm
Northern Illinois
Kubota BX2660
Well, I hate to be this way, but I think H&H needs to get a wake-up call. Years back, I ordered a toothbar from H&H because I liked the way their toothbar had a wrapped v-edge that protected the factory bucket edge when compared to the Markham toothbar. Now that I sold the Kubota B7510, I kept the toothbar for my BX2660 as the buckets have the same dimensions. I went to H&H's website and see they have a wear edge (straight) that I'd like to put on my BX while the bucket is new, and hopefully line up the mounting holes with my tootbar so I can readily change them out. Simple, right? NOT!
I have tried to call many of their distributors in my area, and IF they are in business, the distributors say "H&H Who?" I even sent an email yesterday and one today, but I'm at a dead end. If I had a welder, it'd be a different story, but I don't. I rather not just order a standard 66" flat wear edge, cut it down, and plow bolt it to the factory edge. I was hoping to make this work via H&H, but they have a poor network. I think that anyone who bought from them in the past became "a dealer".
/ H&H Manufacturing Toothbars #2
Sounds like you need to find a welder. Someone you can drop off small parts. It might even be cheaper than buying
My dad always had a guy he would go see to get things welded up for the farm.
Now I have a welder and I use it every time I go out in the garage.
/ H&H Manufacturing Toothbars #3
Call me. I might be able to help you.
Nelson
W. R. Long Inc.
Finally got a response from two distributors of H&H. OUCH! WOW! $450 for a wear edge? I can get a bolt-on wear edge AND tootbar from WR Long that will share the same mounting holes for that kind of lettuce. I'm going to sell my 48" H&H toothbar to recoup a few bucks, and get the WR Long equipment. I think the H&H is much more heavy duty, but I dont need it for ripping rocks and stumps. I mostly need the wear edge to wear against the asphalt and keep me from bending the cheap cutting edge that comes from the factory. What is a good priceto put on a slightly used toothbar if it sells for $450 new?
159120 (A60430)
159120 (A60430)
Eagle Weathervane (A55853)
Eagle Weathervane...
207279 (A52708)
207279 (A52708)
Engine (A59230)
Engine (A59230)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2020 Deere 50G (A53317)
2020 Deere 50G...
