Guessing 750 lbs ballast
   / Guessing 750 lbs ballast #1
Msamt
Enfield, NH
Kioti Dk45SE
   / Guessing 750 lbs ballast #2
thats a chunk of concrete
   / Guessing 750 lbs ballast #3
If that's a 55 gallon barrel I think you are closer to 900 lb. I have a 55 gallon barrel filled about 3/4 full and with all the steel framework in mine it weighs about 850 lb. (10 - 80 lb bags of redimix plus steel)
If it's a 33 gallon you might be right.
Not sure how big the barrel is, wife found 2 of em for me. 9 bags of 80lb quickcrete, a draw bar and some rebar.
   / Guessing 750 lbs ballast #5
Well, you know what you put into it so I guess your figure is pretty close.
   / Guessing 750 lbs ballast #6
nicely done on the pvc pipe. to toss some long handle shovels or like down into them!
   / Guessing 750 lbs ballast #7
This was the approach I was thinking of. I thought 600 lbs should be sufficient for my smaller tractor. Tho I was gonna go with 2-3 bags of cement with lots of rocks, which are free. And the tool holders. I hate to waste the $$ for the draw-bar just to embed it in cement.
   / Guessing 750 lbs ballast #8
I used a 1" diameter solid bar from an old weight lifting bar. (I got the weight lifting barbell set about 50 years ago, weights have long since disappeared but still had the bar) The rest of the steel in mine was scrap I had laying around. (Rectangle tubing thru the barrel and up thru the top, 3/8" flat, etc)
   / Guessing 750 lbs ballast #9
I was going to buy the bolt on Pins from Tractor Supply and weld them onto a piece of angle iron I have (old bed frame found on side of the road), then run two more pieces up for the top link. Then maybe put some welded wire in to help keep it all together over the years.
Rancho
   / Guessing 750 lbs ballast #10
Rancho
I guess I'll have to do the same for pins and bolt them to bed frame. Also gonna try to add a 2" receiver to he back.
CASE 610 Sprayer System 2000 Gallons (A56436)
CASE 610 Sprayer...
Forklift Telescopic Boom W/11ft Extension (New/Unused) (A59225)
Forklift...
JOHN DEERE 7100 - 4R PLANTER (A58374)
JOHN DEERE 7100 -...
Pines 1400 Tubing Pipe Structural Bender (A59213)
Pines 1400 Tubing...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
2014 DITCH WITCH RT45 (INOPERABLE) (A58216)
2014 DITCH WITCH...
