Guessing 750 lbs ballast
   / Guessing 750 lbs ballast #11
I guess I'll have to do the same for pins and bolt them to bed frame. Also gonna try to add a 2" receiver to he back.
I used the TSC "drawbar" because it is very sturdy and has many holes in it to fasten your angle iron uprights to make your toplink with. I also fastened my 2inch to it with a piece if 5/8 allthread.
Thats whats inside this one, easy, available, and i dont own a welder. Yet...
   / Guessing 750 lbs ballast #13
Msamt good job. I have been putting off making one even though I have collected all the parts: plastic 55 gal barrel(check), broken brush hog to steal 3 point hitch(check), 2" receiver(check), pvc for tool holders(check).
Did you actually mix up the 'crete, or just dump it in there a little at a time while adding water? I am going to be pouring a roof on a root cellar soon and maybe I'll have my drum ready by then.
   / Guessing 750 lbs ballast #14
I just dumped in a bit at a time, added water, stirred, pour in more of the mix, a little more water, stir.. Keep on going. It didn't take long, And nothing else to dirty up except a hoe. I probably wouldnt do that if I was pouring for a structure, but for the ballast,.. I figured it would be fine.
Yep, just like James, 2bags, water, 2 more bags. Etc.
2005 Ford F-450 Pickup Truck, VIN # 1FDXF46P65EB16866 (A57453)
2005 Ford F-450...
UNUSED JCT 72" HYD BRUSH CUTTER (A58376)
UNUSED JCT 72" HYD...
JOHN DEERE 3038E TRACTOR (A58375)
JOHN DEERE 3038E...
Giyi Mini 40" Land Leveler (A57149)
Giyi Mini 40" Land...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
