Guessing 750 lbs ballast
   / Guessing 750 lbs ballast #11
I guess I'll have to do the same for pins and bolt them to bed frame. Also gonna try to add a 2" receiver to he back.
I used the TSC "drawbar" because it is very sturdy and has many holes in it to fasten your angle iron uprights to make your toplink with. I also fastened my 2inch to it with a piece if 5/8 allthread.
Thats whats inside this one, easy, available, and i dont own a welder. Yet...
   / Guessing 750 lbs ballast #13
Msamt good job. I have been putting off making one even though I have collected all the parts: plastic 55 gal barrel(check), broken brush hog to steal 3 point hitch(check), 2" receiver(check), pvc for tool holders(check).
Did you actually mix up the 'crete, or just dump it in there a little at a time while adding water? I am going to be pouring a roof on a root cellar soon and maybe I'll have my drum ready by then.
   / Guessing 750 lbs ballast #14
I just dumped in a bit at a time, added water, stirred, pour in more of the mix, a little more water, stir.. Keep on going. It didn't take long, And nothing else to dirty up except a hoe. I probably wouldnt do that if I was pouring for a structure, but for the ballast,.. I figured it would be fine.
Yep, just like James, 2bags, water, 2 more bags. Etc.
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A56857)
2024 AGT LRT23...
2017 Takeuchi TL12R2 Skid Steer, S/N 412100259, Kubota Diesel Engine, Joy Stick Operating Controls, (A59076)
2017 Takeuchi...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
