Guess this tool ...
/ Guess this tool ... #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
Anybody care to guess ....
/ Guess this tool ... #2
I've never seen one of those. The hole in the pliers has to do something with what you are crimping. I am curious. But don't let the cat out of the bag, yet. I want to see what other folks say.
/ Guess this tool ... #4
Looks like the hole in the pliers has a punch beneath it. I don't know what it is but sure looks like a good one!
/ Guess this tool ... #5
It looks like a device to make a hole in the copper tubing stub on a compressor to solder in a valve and the other part crimps the tubing after so it can be soldered back after you remove the valve.
/ Guess this tool ... #6
I'd guess that one part of the tool is for crimping, and the part with a hole in it is for stripping the wire.
/ Guess this tool ... #7
Nipple piercing tool?
Something round goes in the hole, then the little punch pierces it.
Dave.
/ Guess this tool ... #8
Ouch! I don't want to think of the other places...
/ Guess this tool ... #9
A tool for cutting round belting and putting a hole in to hold hog ring to hold ends together to make it "endless".
Now what do I win?
tom
/ Guess this tool ... #10
This is bugging me BlueRiver, I can't think what the half circle and matching side are for just behind the jaw section. They look like they act as a stop for the punch that goes into the hole.
Dave.
/ Guess this tool ... #11
tool for setting demo charges?
punch hole in det cord, crimp blasting caps, etc?
/ Guess this tool ... #14
I actually have a set of these pliers somewhere out in the garage. I never knew what it was. They are belting pliers. They punch a hole in teh end of a belt so you can connect the ends of the belt together with a metal clip.
All good ... here is a hint. It was found in a sewing box ....
/ Guess this tool ... #16
Give credit where credit is due...At least two others have correctly identified the tool..
>>>they're used to fix the half-round drive belt of a small engine, like those of an antique sewing machine.<<<
/ Guess this tool ... #17
Well...It looks like Tom got it right first. I would never have guessed what that tool was for. The question for BlueRiver...Does Tom get a reward? Maybe a nipple or two...oh never mind...
Shop Cart (A68134)
Shop Cart (A68134)
2012 FORD F350 UTILITY BODY (A66091)
2012 FORD F350...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2013 APPCO T-BELT TRAILER (A67714)
2013 APPCO T-BELT...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2003 NV FLATBED CURTAIN SIDE (A67714)
2003 NV FLATBED...
