Guages Work - Lights Do Not
/ Guages Work - Lights Do Not
Well,
I should have added that I have only used the GP heat one time (About 35 degrees) but I am gonna change them
There is just a slight difference in the old GP vs the new ones, They are exact except the nut & washers on top are a little different
I only re-attached GP wires while trying to diagnose/solve lights not working, making sure ALL connections were clean & OK
Lights work now
I think the ground connection under the dash was the culprit for light failure, I am just a little surprised any thing else worked
I removed the wires. ground the paint off, used a glob of diaelectric grease, used a better fastener, & have all lights
I am going to replace switches & GP in near future, probably when I remove & clean the fuel tank
Thanks so much for all replies & input
David
MGY Shop Heater (A60463)
MGY Shop Heater...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2015 John Deere CX15 (A60462)
2015 John Deere...
Chance Quick Attach 60" Mulching Head (A60463)
Chance Quick...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
