GT2544 Headlight Problems
/ GT2544 Headlight Problems #1
Jim_Zis
Charlotte Hall, MD
Help, Tho I love my Cub, when I rinse it down the headlight unit gets filled with water and all the dust and dirt settles inside at the bottom of the lens. Also the cheap reflector plastic inside is just flopping around. Does CC make another headlight assy that will fit which does not have these problems???? Does any aftermarket company make a headlight unit that will fit????
/ GT2544 Headlight Problems #2
To get the accumulated dirt from the headlights, you should use compressed air. It works great. Just blow it through the vents it cleans right up. Assuming that yours is the new designed 2006, I highly doubt anyone makes anything aftermarket for it as far as headlights.
/ GT2544 Headlight Problems #3
I use mine in some dusty yards and never had a problem with headlights collecting or accumulating anything between the lens,make sure they fastend correctly.Mr wiggles thanks for the idea with the tail lights,they look great I will post a another picture ,this one is a little dark and the 2180 is painted with a copper hammer finish from rustuolem,more needs to be done.
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Angle Broom (A64126)
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
Stout Buckets 66-9 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets 66-9...
