Ground hornets!
/ Ground hornets! #1
JohnP3616
Trinity, TX
Mahindra 3616
I hooked up my trailer, backed it up to my shop door, and was slowly driving my mower up the loading ramp when - BAM - a hornet nailed my wrist. I smashed it and continued loading the mower. My wife came out and I cautioned her just as she took off running. We went in the house and put baking soda poultices on our stings. We very carefully went back out and discovered a hole in the ground about three feet from my trailer tailgate that was crazy with hornets. I had a tiny amount of wasp spray that I sprayed directly down the hole. Ticked them off. They buzzed so loudly it sound like a magma about to erupt. Lacking anything else I poured about two gallons of diesel down the hole. Went back the next day and didn’t see a single hornet. They were very aggressive, mean, nasty little pests.
This is the second nest I’ve encountered. The first one I filled with expanding foam that had insecticide in it. I need to keep it on hand, it worked very well. Spraying it down the hole was very satisfying, too.
For several years we were bee keepers, but my wife became increasingly allergic each time she was stung and this hornet sting caused her hand to swell and was painful for 2-3 days. My sting was just an itchy red spot.
You can’t be too careful.
/ Ground hornets! #3
I use tempest or sevin powder, takes a day or so to get them all, but it works.
Was out trimming bushes, got to the last one and got hit in the back, YJ under the bush I was trimming. Hole big enough for a golf ball.
I stayed calm and walked away so they did not chase me, this time.
3rd nest I wiped out this year. nasty little demons.
/ Ground hornets! #6
I use baby powder loaded into a turkey baster. The local parks pump me on to it. It's less toxic, and just works, at least around here.
All the best, Peter
/ Ground hornets! #7
I used to use gas, but as I got older, I became more mindful of my land. Now, it's soapy water. As effective as anything else. I will say, burning them was much more fun and satisfying...
/ Ground hornets! #8
I don't bother them unless they are in some critical area. Everything has it's purpose, even if we don't like it.
Well, except cancer, smallpox, diptheria and other diseases.
For some reason I don't get stung as often as other people do. I can walk past a nest and they will fly past me to sting somebody else. When I do get stung it only bothers for an hour or so.
I'm sure that will change someday and I'll become deathly allergic.
/ Ground hornets! #10
We leave plenty of YJ, mud daubers and cicada killers alone to control other pests. but when they get close to where I need to be, they are gone.
I had a bald faced hornet come 10 feet into my garage where I was just moving stuff around and attack me. I won't let them within 100' of my house since then.
I try to be careful not to harm bees, and have plenty of plants they love to cover. Lots of bees that I walk past every day, no reaction from them at all, like the mud daubers, as long as they are happy and can find food, they don't bother anyone.
/ Ground hornets!
I was surprised at how big their hole was. I am normally a good steward of my property, but I needed these things gone. I needed to finish loading up my trailer and my wife is way too allergic so out came the diesel can. I figured just a little would fill the hole, but it didn’t. Even a couple of gallons didn’t fill the hole. That’s a big hole with lots of hornets. Scary when I think of my grandkids playing around there.
/ Ground hornets! #12
2 gallons?🤪
When activity dies down in the evening a half cup of gasoline and a match on a really long pole.
"They blowed up good, they blowed up real good." John candy
/ Ground hornets! #13
Love my bee suit. A bit of work to get it all on, but oh so very satisfying digging the little buggers out. :)
/ Ground hornets! #14
I don't set it afire. I wait until after dark when they are all in the nest, then pour ½cup of gas into the hole. Next morning they are all dead. I once set it afire and found myself standing in a ring of fire.
/ Ground hornets! #15
20250823_153856.jpg This yellow jacket nest was in an old stump on my mother's lawn. I'd have sprayed it, except that a skunk got there first.
There were a few left when I first discovered it. MessieurLePe came back that night and dined on leftovers.
We've been mowing past it all summer, my BIL had just done the lawn 3 days earlier.
That would make a great song title!
/ Ground hornets! #16
Just poured a chp of gasoline on another nest...in the ground this time.
That makes three dustings by pros and two attempts by me for jackets and hornets this year.
A new property record.
/ Ground hornets! #18
Be careful with the baby powder, if it has asbestos in it the hornets might get cancer!
If the environmental people find the BP has asbestos you may have to remove it going through all the safety protocols.
It's probably cheaper just to walk away from the property.😖
/ Ground hornets! #19
A few years ago I went to hook up my rotary mower and found that hornets had built a nest under the deck. I carefully hooked it up then started the tractor, engaged the pto, let the clutch out and suddenly there was no nest!
/ Ground hornets! #20
I have to do some bush hogging at the property and always dread doing it this time of the year. Got lit up pretty good a couple of years ago by a nest.
(2) UNUSED 16.9-24 TIRES ONLY (A64280)
(2) UNUSED 16.9-24...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 FREIGHTLINER...
2022 EZ-GO ELITE...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
