Mowing Grinding Noise
/ Grinding Noise #1
cutter49
Conroe,TX
JD ZTRAK 915
When I push the lever down to engage the blades and also pulling lever up to disengage, there is a grinding noise. The noise is not there while mowing and does not interfere with mowing, it only grinds for about 2-3 seconds each movement of the lever. Anybody have ideas what I am facing here?
/ Grinding Noise #2
are you engaging blades at a higher rpm? if so try low engine speed, hopefully will hellp
/ Grinding Noise
I tried on the lowest rpm, it still was grinding, but at a lower decibel and for a shorter time. It sounds like gears in a bind and then releasing.
/ Grinding Noise #5
is this on a zt or bx belly? hopefully not a pto clutch wear issue.
/ Grinding Noise #6
Have you checked for lube in the mower gearbox?
/ Grinding Noise #7
While checking the oil in the gearbox, hopefully you have lubed all the points on the deck and both ujoints on the pto axle?
2022 EZ-GO ELITE...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
