Mowing Grinding Noise
/ Grinding Noise #1
cutter49
Conroe,TX
JD ZTRAK 915
When I push the lever down to engage the blades and also pulling lever up to disengage, there is a grinding noise. The noise is not there while mowing and does not interfere with mowing, it only grinds for about 2-3 seconds each movement of the lever. Anybody have ideas what I am facing here?
/ Grinding Noise #2
are you engaging blades at a higher rpm? if so try low engine speed, hopefully will hellp
/ Grinding Noise
I tried on the lowest rpm, it still was grinding, but at a lower decibel and for a shorter time. It sounds like gears in a bind and then releasing.
/ Grinding Noise #5
is this on a zt or bx belly? hopefully not a pto clutch wear issue.
/ Grinding Noise #6
Have you checked for lube in the mower gearbox?
/ Grinding Noise #7
While checking the oil in the gearbox, hopefully you have lubed all the points on the deck and both ujoints on the pto axle?
Zero Turn Mower (A59231)
Zero Turn Mower...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
2012 Dodge Grand Caravan Van (A61574)
2012 Dodge Grand...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
