Mowing Grinding Noise
   / Grinding Noise #1
cutter49
Conroe,TX
JD ZTRAK 915
When I push the lever down to engage the blades and also pulling lever up to disengage, there is a grinding noise. The noise is not there while mowing and does not interfere with mowing, it only grinds for about 2-3 seconds each movement of the lever. Anybody have ideas what I am facing here?
   / Grinding Noise #2
are you engaging blades at a higher rpm? if so try low engine speed, hopefully will hellp
   / Grinding Noise
I tried on the lowest rpm, it still was grinding, but at a lower decibel and for a shorter time. It sounds like gears in a bind and then releasing.
   / Grinding Noise #5
is this on a zt or bx belly? hopefully not a pto clutch wear issue.
   / Grinding Noise #6
Have you checked for lube in the mower gearbox?
   / Grinding Noise #7
While checking the oil in the gearbox, hopefully you have lubed all the points on the deck and both ujoints on the pto axle?
2020 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A53426)
2020 FREIGHTLINER...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A53473)
Gooseneck...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
