grinding noise while turning
   / grinding noise while turning #11
The clunking still happens when the diff is on during turns - is that normal? Thank you again.
Yes turning with diff lock engaged defeats the purpose of pinion gears/shafts in diff.
   / grinding noise while turning #12
I seldom use differential lock on my equipment except for rare occasions. Needing it indicates that it is too wet and I should wait for the ground to dry out more or that I am over working the tractor with too high of a draft load. It is helpful for small slick spots on occasions though. If you lock up the rear wheels you should expect to go straight only.
I have been using it quite a bit while chisel plowing. I hope I had not messed anything up?
The tractor has 140hp and the chisel plow has only 11 shanks, I thought it should pull it without too much trouble.
Perhaps the tires are too worn? How do I measure the wear of rear tractor tires - can't find a method anywhere online.
   / grinding noise while turning #14
I've utilized the diff lock when plowing many acres with my 4255 with no known ill affects BUT I always disengage DL when turning. IMHO there's not a lot of difference in traction on worn vs new tires. Some tractor pullers prefer worn tires. Look at the new style short cleat tires built specifically for tractor pulling.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 JOHN DEERE 444L WHEEL LOADER (A52709)
2020 JOHN DEERE...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
2016 INTERNATIONAL LF687 SLEEPER (A58018)
2016 INTERNATIONAL...
2019 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A58018)
2019 VOLVO...
