Grillo G107 Clutch
/ Grillo G107 Clutch #1
Vilkas
El Cerrito, CA
Grillo G107
I recently purchased a Grillo G107 plus a few attachments site unseen. The price was good enough that repairs/ a few parts are not too much of a concern,...I think. Well, got the engine running, tiller attachment working, dozer blade cleaned up a painted, and a little flail mower maintenance. One last problem, the clutch does not disengage.
It runs forward and backward, as well as all gears. But, I have to "pop" it into gear as the clutch does nothing (obviously it is not in full service yet as I do not want to create more damage). That is it moves whether pulled up or released; no difference. I adjusted the cable to the proper slack as well as tightening it up quite a bit. No luck.
I spoke to earthtools about it and they suggested the cable adjustment (as mentioned above). I was wondering if anyone else has come across this problem on a Grillo (found a similar thread regarding a BCS). I plan on calling ET again tomorrow as well as pulling the engine and taking a look this weekend.
If anyone can share their insights, it would be much appreciated.
/ Grillo G107 Clutch #2
Hey Vilkas,
Welcome to the group.
I've never heard of a Grillo clutch seizing, but it may be your problem. Take the engine off the machine and the clutch off the engine. Place it in a vise and squeeze it. If it pops, that was your problem. Otherwise, you may need a new clutch or new clutch facings if the clutch material disintegrated and lodged in the housing. I've not had any of my customer's clutches fail, so I haven't been in a clutch yet. You'll need to talk to Earth Tools about procedures on rebuilding a clutch.
Good luck.
/ Grillo G107 Clutch #3
It was probably left engaged for a long time unused and it stuck.
Thanks for the responses. Well, I took the clutch off and shipped it off to Earth Tools. I thought about putting it in the vise, but it was deflecting as bit and had no slack. Perhaps it can be fixed, or I may be buying a new one...
I believe it was left engaged for quite a while before I bought it.
Turns out the clutch was shot, beyond repair. The new clutch is on and working fine. Now the flail mower is locked up. So it goes...
/ Grillo G107 Clutch #6
The joys of used equipment.
I bought a used chipper recently and tested it before I bought it. Even with that I had a couple small issues to resolve. But, hopefully the bargain price makes it all worth the effort...
Well, the flail mower is now operational. Yes is deed, the joys of used equipment. But I did get a piece by piece education for my efforts...
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
New/Unused ATS 80 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 80...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
