grey kubotas
/ grey kubotas #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Are all grey market kubotas equipped with the reverse pto? or is it only specific units. Anyone know what numbers i need to look out for? Also.. I understand that the local dealers won't seel parts for the greys. How do you tell which models are domestic and which are grey?
thanks,
Soundguy
/ grey kubotas #2
Here is a list I pulled from Kubota's Web Site Here is a link Kubota Gray Tractor List
Here is a link to tips on spotting a gray market tractor. Gray Market Tips
"GRAY MARKET" TRACTOR LIST.
Kubota Models Designed and Manufactured for Japanese Market**
A-13
A-14
A-15
A-17
A-19
A-30
A-155
A-175
A-195
B-10
B-40
B52
B72
B92
B1200
B1400
B1402
B1500
B1502
B1600
B1702
B1902
B5000
B5001
B6000*
B6001
B7000
B7001
B1-14
B1-15
B1-16
B1-17
GB13
GB14
GB15
GB16
GB18
GB20
GB110
GB130
GB140
GB150
GB160
GB170
GB180
GB200
GL-19
GL-21
GL-23
GL-25
GL-26
GL-27
GL-29
GL-32
GL-33
GL-35
GL-40
GL-43
GL-46
GL-53
GL200
GL201
GL221
GL240
GL241
GL260
GL261
GL268
GL277
GL280
GL281
GL300
GL301
GL320
GL321
GL337
GL338
GL350
GL367
GL368
GL400
GL417
GL418
GL430
GL467
GL470
GL530
GL600
GT-3
GT-5
GT-8
GT19
GT21
GT23
GT26
GT30
KJ11
KL21
KL23
KL25
KL27
KL30
KL33
KL36
KL43
KL28H
KL31H
KL34H
KL38H
KL41H
KL46H
KL50H
L27
L33
L46
L120
L140
L170
L200*
L240
L260*
L270
L280
L350
L1500
L1501
L1511
L1801
L1802
L2000
L2002
L2200
L2201
L2202
L2402
L2600
L2601
L2602
L2802
L3001
L3202
L3500
L3602
L4202
L4214
L1-18
L1-20
L1-22
L1-24
L1-26
L1-28
L1-33
L1-38
L1-43
L1-45
L1-185
L1-195
L1-205
L1-215
L1-225
L1-235
L1-245
L1-255
L1-265
L1-275
L1-285
L1-295
L1-315
L1-325
L1-345
L1-385
L1-435
L1-455
T22
X-20
X-24
XB-1
*Although these model numbers are common to U.S. and Japanese Kubota models, there are material differences between the models.
**As of August, 1999.
/ grey kubotas #3
Is there such a thing as a grey market BX tractor????? What would be the differance?????
/ grey kubotas #4
I don't think you have to worry about it as much on the newer tractors. Kubota USA sued all the importers to keep them from bringing in the grey market tractors. I would just read the link in my earlier post and it gives you several items to look for to determine if the tractor was built for the US market or not.
/ grey kubotas
thanks guys
Soundguy
/ grey kubotas #6
I have a Grey Market L2201DT Kubota. It has a standard PTO that turns the correct direction. I order parts for an L245DT (american counterpart) when I need parts and maintenence items. Only difference I have found so far is the PTO , the Grey has 4 speeds. I assume there are a few gears that are different inside. I did have to split the tractor to replace a bent PTO shaft but located a used shaft quite easily. 25 years old and running strong!! Naturaly there are no ROPS or PTO shield .There is a ROPS program availlable from Kubota for the older tractors. I could order Rops for an L245DT that would fit perfect , but it would not fit under my garage door !
