Gresen Valve
/ Gresen Valve #1
Desert Rancher
MF super 90 Ac D17
I have a Gresen valve on a loader. Casting #2753 above outlet side and a K0?, 6, or 8 stamped on a machined spot on top of the relief valve. Anyone know the specs, what type of valve this is, or (most importantly) where I could get parts to rebuild it? It's paired with the pump listed in my other post above.
Thanks
/ Gresen Valve
Hey, thanks J.J.
I'll see what I can ferret out
/ Gresen Valve #4
Parker purchased Gresen several years ago so you might try some Parker Distributors. Gresen was based in Minneapolis, MN. or a burb there of.
/ Gresen Valve
Thanks for the info. Went to Parker and there site had a note saying they no longer supported Gresen. Didn't find anything cross referenced to my valve. Was told it came with the "Dual" loader on the tractor by the last owner. I'll continue to poke around and see what I come up with. Keep you posted
/ Gresen Valve #6
I got a replacement section for the Gresen valves on my backhoe from Baum hydraulics. I talked to a technical guy on the phone and he identified the part I needed. Depending on your problem it may be cheaper to replace the whole thing with a generic unit from Baileynet or Surplus Center.
Baum Hydraulics Corp
/ Gresen Valve
Funny you should mention that. Was just off looking at their website. Thought I'd give them a try in the next couple days. Sure appreciate the tip. I'll post back after I visit with them. Thanks again
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2025 IRANCH IRLMB Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 IRANCH IRLMB...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2007 International 8600 Parts Truck (A63689)
2007 International...
