Great wire rope trick
/ Great wire rope trick #61
Look guys I splice wire rope for a living. It is no joke when it fails. We hand splice very seldom anymore. There are a few drilling companies out there that prefer this method for "spinning". The actual industry standard for a pull test on any wire rope sling is 3x, we pull 5 x. I stand corrected.
My question is why would someone WANT to hand splice when wire clips do the job? We sell wire rope clips upto 2" diameter wire rope.
I like this thread.
/ Great wire rope trick #62
I want to thank the original poster for this long and interesting thread.
This past weekend I was going thru my accumulation of junk and came across two pieces of 3/16 stainless steel cable. One about three feet long and the other a little over six. No ends on either piece.
I remembered reading this thread and decided to try the rope trick.
It was very easy after I got the hang of it. Now I have two slings I can use around the shop instead of a couple of pieces of useless junk.
Thanks again,
Bill
/ Great wire rope trick #63
where I am from this is called a farmer's eye. I have only used it with wire rope and I do splice in the ends or clamp them. I have seen it pull out without breaking the wire. Try not to make to small an eye, as the longer the eye, the less chance of it pulling out. Unless I am using that eye for a stationary line, I splice my eyes with a 3 tuck. It will break the main line before it pulls out, and can go through a tommy moore block or over a roller without harm.
With the rope, actually, each side of the loop takes half the load, so the one strand is worth two strands. still, it doesn't take but just a few minutes to make a proper splice in rope.
/ Great wire rope trick #64
I was going to drop out of this thread but...
"With the rope, actually, each side of the loop takes half the load, so the one strand is worth two strands. " Don't you mean that one strand carries the same force as the two strands? And as the two strands are carrying 1/2 the force then the single strand must also be carrying 1/2 the force. Therefore the single strand force is greater (proportionately) than the two strands and hence will break at a lower force applied to the rope.
I will qualify this by saying refer to my last post and say this only applies for the 3 strand rope example.
Cityfarma
PT Wheel Driven Fertilizer Spreader (A64119)
PT Wheel Driven...
COLE 4R TWIN ROW PLANTER, 3PT (A64280)
COLE 4R TWIN ROW...
2019 JOHN DEERE XUV560E GATOR (A64280)
2019 JOHN DEERE...
NEW CAST IRON FARM BELL KIT (A64281)
NEW CAST IRON FARM...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
