I have learned a ton of stuff from reading this forum, so I thought I would share some of my experience. If you have ever broken a winch line or wire rope and needed to put a new "eye" on the end, then this is the trick for you.
My crew worked for more than 10 years using a winch rated at 25,000 lbs and during that time, we snapped the 1/2 wire rope hundreds of times. We did not use "U Bolt" clamps on the line to make new eyes, we only used vinyl tape! With all those breaks, I cannot remember a single time where our eyes failed (often the factory built eyes would fail because they were old and abused - if we ever had any doubts, we would cut the factory "crimp eye" off and weave a new one.
This whole process took less than 10 minutes and worked like a charm. This technique will work for any rope (steel strand, nylon etc regardless of the number of individual strands), but it works especially well with wire rope.
ONE WORD OF CAUTION >>>> ALWAYS WEAR SAFETY GLASSES WHEN WORKING WITH WIRE ROPE!!!!!!!!!!!! <<<<
Once when I was tying one of these, one of the strands slipped out of my hand and swept right across my face leaving deep scratches in the middle of my safety glasses. Had I not been wearing them, I would really have screwed up my eyes. I don't always wear them like I should, but this is NOT the time to be lazy.
Concepts:
The larger the loop and longer the tail, the stronger the eye. This comes from the fact that more length means more friction, and more friction means more strength. When I worked with 1/2 inch winch lines, we made the loops between 8 and 12 inches around with 6 to 8 inch tails.
Now for the instructions. I used nylon rope for these pictures, but again, any rope (wire or otherwise) will work so long as it is woven strands.
1- Decide how big you want the loop and unwind the rope 1.5 x that length. If the rope has three strands, separate one of the three strands. If it has 9, separate them into one group of 5, and the other group of the remaining 4 (you get the idea) Lets assume for this example we want the loop length to be 12 in (all the way around the eye), so unwind about 18 in of rope
2- Here is the big trick, cross the two unwound groups and wind them back together so they fit back into the groves (so it looks like the rope started out)
3- Once you get to the bottom of the loop, wind the remaining 6 inches together and tape up the end. You don't have to tape the end (we often didn't when we knew we would be tearing up the winch line otherwise. In case you were wondering, our winch started out with 2000 ft of line!)
With that you are done! Thats pretty much it for wire cable tricks, but I have a bunch for regular ropes if anyone is interested. Enjoy!
Concepts:
