Greasing the joints
/ Greasing the joints #1
GamblerAcres
Ohio
2018 Kubota MX5200
Mx5200 4x4 HST with 22 hours. I decided to go ahead and grease the axle points since I use it in very wet/muddy conditions. I applied grease to the front axle gear case support. It got harder with each pump. I figured it was filling the void and building pressure against the old grease. I was expecting to see grease flowing from the joint at some point. On the 6th pump I heard a pop and the pressure released.
Did I break a seal or something or did I just push some old stubborn grease out?
Also, what size is the breather plug on the front axle support. Should I see grease coming out of all the joints?
/ Greasing the joints #3
If you didn't remove the breather plug FIRST then YES, probably an o-ring. :mur:
The breather plug is on the axle support. I'm talking about the one on top of the wheel hub joint
/ Greasing the joints #5
Most likely you simply pushed out old hardened grease. The "pop" you heard was the old dry skin of the old grease breaking under pressure of the new stuff.
Breather plug on the front axle pivot pin - never heard of such an animal. I have a front & rear grease zerk on my front axle pivot pin - no breather plug.
Must be a different kind of animal...........
Mine also has a front and rear zerk on the pivot pin. Only difference is the front zerk has the breather plug. It's a square pipe plug.
2013 Caterpillar 930K Articulating Wheel Loader (A61567)
2013 Caterpillar...
2008 Freightliner B2 Bus, VIN # 4UZABRDJ98CZ17952 (A61165)
2008 Freightliner...
2018 Infiniti Q60 Coupe (A61569)
2018 Infiniti Q60...
New/Unused Landhonor Quick Attach Receiver Hitch (A61166)
New/Unused...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2013 Ford F-750 Chip Dump Truck, VIN # 3FRNF7FC4DV778235 (A61165)
2013 Ford F-750...
