Greasing front axle
/ Greasing front axle #1
nosaj2
none yet
So there are two fitting on the font of the tractor along the front drive shaft. The one nearest the rear of the tractor pushed grease out after 2-3 squirts. The front one did not. Even after 4-5. Should I be expecting grease to exit somewhere?
Also my new 2515h seems to not have a zerk for the brake pedal. Is this right? Or am I just missing it.
/ Greasing front axle #2
Can you feel grease going in?
One of my 3725's center pivot zerks did not accept grease at first. After trying with the wheels off the ground it started working, and now takes grease with the wheels on the ground.
Good point. I thought it was going in. But maybe I should remove the zerk and make sure.
/ Greasing front axle #4
I ALWAYS take the weight off the front end pivot when greasing it...
SR
/ Greasing front axle #5
86 (A63290)
86 (A63290)
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2013 CATERPILLAR 259B3 SKID STEER (A65056)
2013 CATERPILLAR...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2015 Yamaha 350hp 4-Stroke Outboard Boat Motor (A66738)
2015 Yamaha 350hp...
2018 FORD F-150 (A67714)
2018 FORD F-150...
