Greasing Front Axle Support
   / Greasing Front Axle Support #31
Any of you guys know how to grease a 2 WD axle pivot ???? L - 2501
Most of them I have seen just have one zerk, Put a couple of pumps into it.
   / Greasing Front Axle Support #32
YEP, and on my CUT I used some 1/8" tube to bring the zerk to a more accessible location so that I don't need to crawl under.
Greasing is messy enough without crawling in the dirt.
All the other zerks are readily accessible from the vertical.
   / Greasing Front Axle Support #33
On the L2501 the 2 wd front end pivot has no zerks. Just a plug in the rear of the pivot. No way to grease that I see. Nobody here has one of these tractors ? What do you do about it if anything ??? Thanks, Pete
   / Greasing Front Axle Support #34
I have never seen a 2wd drive tractor front axle pivot without a zerk
   / Greasing Front Axle Support #35
Page 55 of the operators manual doesn't show greasing a 2 wheel drive. It shows greasing the 4 wheel drive though
   / Greasing Front Axle Support #36
So is it like a sealed bearing?
   / Greasing Front Axle Support #37
Must be. But why the plug on the backside of the pivot?
   / Greasing Front Axle Support #38
Why not take that plug out and take a look in there with a strong light.
   / Greasing Front Axle Support #40
I am going to do just thas. I have some grease fittings coming...BPST and Metric. One will fit cuz it ain't SAE. I also have a grease needle coming so I can try to get grease into there with it....as I am sure I will blow out a seal if I put too much pressure on it.j
I Will check it out more later...….but it sure does not have a grease fitting and the book does not address this or say why. This thing has got to have grease as it moves a lot.
Pete
202483 (A54757)
202483 (A54757)
Bucket (A55973)
Bucket (A55973)
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A57453)
2013 Dodge Charger...
Great Dane Van Trailer 1989 (A56435)
Great Dane Van...
