Greasing Front Axle Support
   / Greasing Front Axle Support #21
That makes two of us :-( I haven't seen anything in my WSM about one, nor could I find one yesterday when looking for it after reading about it on here. I'm generally **** about greasing; heck, I loose sleep at night wondering if I missed one or didn't get the right amount of grease in.
I had read in the manual about being sure to grease the TWO zerks on the hydro-pedal. Guess what? There are THREE zerks on mine. I just found a third one after 5 years. I'm hoping that someone can tell me exactly where the two on the front pivot point is located.
Well every tractor I have owned has had 2 zerks on the front axle. and I guarantee your L3400 has 2. One in the front and one in the back. Unless it has been broken off or something.
   / Greasing Front Axle Support #22
I'm agreeing fully with k0ua's several posts. Matches my experience.
   / Greasing Front Axle Support #23
James - You are dead-on right! I found mine right where you said it should be !!! And I got lucky - the plug in mine was not overly
tight. Got 'er juiced up with 2 pumps and re-plugged. Thanks a million. You 'da man!
   / Greasing Front Axle Support #24
I am glad to help.
   / Greasing Front Axle Support #25
Sorry to bump old thread...
Are you guys using the same HD EP Grease for the front axle support zerks as you are your implements, FEL, backhoe, etc??
Or changing it to something different?
   / Greasing Front Axle Support #26
Same grease ..:)
   / Greasing Front Axle Support #27
What about a 2 WD ?? I have one and it has only a plug in the rear part of the pivot support. Nary a word in the manual about what to do. Anyone know about these ?
Thanks much.
   / Greasing Front Axle Support #28
Same grease.
   / Greasing Front Axle Support #29
Yes - my M6040 has two grease zerks. Front & back. I couldn't figure out why - " remove the axel breather plug". Then I carefully read James ( K0UA ) previous post. The grease from supports goes inside the front axel. It makes sense to remove the breather plug.
When I grease my M6040 front axle - all the grease remains outside. And how.......
   / Greasing Front Axle Support #30
Any of you guys know how to grease a 2 WD axle pivot ???? L - 2501
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2003 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2003 TRAVIS BODY &...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A55302)
2017 Ford F550...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
