GREASEING DEBATE
/ GREASEING DEBATE #21
Well....I'll probably wash Rising Sun this weekend, after a job I have on Saturday. I'll get all the grease off then. It won't look so bad after a bath, so when I do it next time I'll probably leave the grease on her.
/ GREASEING DEBATE #22
One of our mowers has 42 grease zirks,I don't take the time to wipe off any excess,but I do use surgical latex gloves while servicing.
/ GREASEING DEBATE #23
Frank-I'm a neatnik also. Since my tractor is fairly new I just greased her for the first time this weekend. I wiped the ones that show on the outside for the same reasons someone else mentioned, I don't want to rub my shirt up against it. The rest of them I just left it on. Latex gloves and workshop paper towels really do work great.
Richard
/ GREASEING DEBATE #24
with petroleum products I use Nitrile gloves. they are much more resistent to punctures also.
I use cheap paper towels to get the bulk grease off the joints and fittings then shop towels.
/ GREASEING DEBATE #25
Nitrile gloves,I'll have to try some,the Latex gloves are a little thin for this type of use,but better than nothing...Thanks for the tip.
/ GREASEING DEBATE #26
Not trying to be funny here...
What is everbody doing that they get grease all over them from their tractor?
I use my tractor a good bit and do not have this problem.
/ GREASEING DEBATE #27
I get grease contact when attaching / removing things from my 3pt hitch. I keep the threads on the toplink lubed, and the adjustable link has a lube point, and I lube the hitch pin points and on the top link swivel as well. Probably overkill, but then.. I never did this on my yanmar 1700, and I replaced the adjustable lift link once.. and it might have been a failure due to no lube.
Soundguy
<font color=blue>"What is everbody doing that they get grease all over them from their tractor?
I use my tractor a good bit and do not have this problem. "
Caterpillar 318BL Excavator (A65579)
Caterpillar 318BL...
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2015 Kubota ZD1211RL 74in Zero Turn Mower (A64553)
2015 Kubota...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
