Grease?
/ Grease? #1
TWINKLE_TOES
I have a new TL421 loader and BT751 backhoe and at 10 hours I greased it. at twenty hours I ran out of grease in the gun. I believed that the gun contained Molybdenum Disulfide as recommended in the loader manual.(High quality grease designated "extreme pressure" and containing Molybdenum disulfide is recommended)
The grease in the gun was "Marine Grease" identified as follows:
Base Type: Aluminum Complex
Color: Blue
N.L.G.I. No.2
Warning: Contains Mineral Oil,Aluminium Benzoate,Fatty acid Hydroxy Complexes and Calcium Dinonylnaphthalene Sulfonate.
Finally hear is the rub. It also contains this label:
:IMPORTANT:
Do not mix greases of different base type. Use a solvent to remove and clean out all traces of incompatable grease before repacking.
I usually use MOLY DISULFIDE from Case in most everything else, which is a Mineral base with Molybdenum Disulfide added.
I sure don't want to pull every Zerk and pin in the tractor and backhoe and remove every trace of incompatable grease.
Seems like both are mineral base even though the marine grease is a little elusive by stating the base type as "Aluminium Complex"
If anyone could help I would really appreciate it.
/ Grease? #2
Twinkle Toes, my tractor manual says to use a "multipurpose type grease" and the loader manual says to use "SAE multipurpose grease." Not very specific. I think most lubricant manufacturers say to not mix the different types, and of course, in some applications that's probably important. But for our purposes, I don't think it's critical at all. I just wouldn't worry about it, if I were you so long as it has enough grease.
Bird
/ Grease?
I like the way you think, maybe cause I'm to darn lazy to "remove every trace". My tractor manual is the same as yours, it's reading the loader and backhoe manual that got me in trouble.
/ Grease? #4
Maybe I'm wrong here, but I just look for a grease that has the NLGI #2 rating. I switch between brands all the time. It all depends on whether I'm shopping in Wally Mart or Farm and Tractor.
I've alway figured the rating is the key. Have I been wrong all this time?
/ Grease?
Bill,
I don't know if you have been wrong all this time or not. I have done it pretty much like you. I think Bird's common sense approach is right. In our applications keeping things greased is key.
I did send an email to CRC (Corrosion Reaction Consultants), manufacturer of the marine grease I used. The trade name is "Sta-Lube". They wrote the warning on the tube, they should be able to explain what it means.
I'll keep after them until they provide an answer or tell me to pound sand. I will post their answer, either way.
/ Grease? #6
Thanks, please do keep us updated.
As to Bird, you're right, he overflows with common sense.
/ Grease?
I called CRC(Sta-Lube)technical assistance @ 800-521-3168. I talked with a chemist named Melody. I didn't have to pound sand. I received a pretty good grease 101 lecture. She was very helpful, and did not mix words. The greases I used are not compatible . Clean out the old grease and replace.
Most of the Zerks I have greased are for hinge pins and I will probably just squeeze more grease through them, maybe clean the easier ones. I did recheck the Kubota lube recommendations, my WORKSHOP MANUAL says "General Purpose Grease", my OPERATOR'S MANUAL (page 12) says Molybdenum Disulfide (EP)
Most (80%) of the greases on the market are a Lithium base so this problem is probably not as severe as it might sound. I got lucky by picking one of the most incompatible bases (Aluminum Complex) This grease is fine and dandy for wheel bearings on boat trailers. I would bet that a fair percentage of wheel bearing failures on boat trailers are due to mixing the Aluminium complex base with other base grease as opposed to salt or fresh water intrusion.
This is what I think I know after a day of research:
Use good quality E.P. (extreme pressure) grease meeting NLGI Grade-2 specs with an operating range of plus 325 degrees F to minus 10 degrees F. Try not to mix brands because different thickeners are used which may be incompatible and have lower heat resistance and shear stability. The most recognizable unsatisfactory mixtures, are those involving lithium and sodium greases, and clay and most soap greases. Don't mix synthetic and natural greases.
The attached URL contains a compatability table:
http://www.ampol.com.au/prods/greases/grease_compatability.html
Another link I stumbled on by CALTEK has recommendations of lubrications for blue, green, red and orange:
http://www.datateck.com.au/lube/caltx_au/
Another link that reinforces what bird has posted about DELO 400: http://www.ampol.com.au/prods/delo/delo.html
Hope this helps if not call Melody and get the straight skinney. (how do you make one of those little upside down smiley faces on this board?)
/ Grease? #8
Twinkle Toes, I don't know about upside down smiley faces, but if you click on the FAQ at the top of the page and then click on "Can I use HTML?" or scroll down, to read about MARKUP, you can find out how to do several things./w3tcompact/icons/shocked.gif/w3tcompact/icons/cool.gif/w3tcompact/icons/smile.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/wink.gif
And maybe the type of grease is more important than I thought, but then I don't suppose I've ever bought any of the Aluminum Complex grease.
Bird
/ Grease?
Thanks Bird,
Maybe you should get some of that fancy marine grease put it in your B2710 and then you could go fishen on your tractor./w3tcompact/icons/wink.gif
/ Grease? #10
Yeah, if my creek hadn't dried up./w3tcompact/icons/frown.gif
Bird
/ Grease? #11
Being the owner of several boats over the last few years. I think I may know why the label says not to mix different greases. With an Aluminum Outdrive on a boat the different materials can cause very bad corrosion of the whole outdrive. With an outdrive never us graphite based grease to lubricate the parts of drive that will be in the water.
ronh
/ Grease?
Ron,
You sure have it right with graphite grease and boats, but I think there are two different mechanisms working here.
The graphite is bad with respect to galvanic corrosion. Dissimilar metals that are separated in the galvanic series, (in the presence of an electrolyte, salt water or ionized water) form great little batteries that result in corrision of the least nobel metal. In your case it is the Aluminum alloy casting. That is why larger boats have sacrificial underwater Zinc plates (Zinc's) and outboards or I/O's have a Zinc rudder behind the prop which is also used to offset the prop walk of the engine. Zinc is one of the least noble of the metals followed by Aluminum and it's alloys. Graphite is the most noble of the metals found on boats.
The base mixing in the grease is a chemical reaction between incompatable bases that results in a reduction of their lubricating qualities. No electrolyte is necessary.
2015 Honda Accord Sedan (A61574)
2015 Honda Accord...
8in Channel Tooth Bucket Mini Excavator Attachment (A61572)
8in Channel Tooth...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
Brown 826 (A64119)
Brown 826 (A64119)
2006 FREIGHTLINER COLUMBIA T/A 6X4 DAYCAB TRACTOR TRUCK (A59912)
2006 FREIGHTLINER...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
